Question about EliteGroup PM800M2 Motherboard
Hi! im going to upgrade my pc, it currently use 256mb ddr226 memory, and i would like to add 512mb ddr400... my mobo is pm800-m2 pls help if it its possible cause i cannot find ddr266 in the market... thanks
    President:
  • 2,351 Answers
Hi marlonpanis, included within the link below is DDR266MHz memory;
http://www.tigerdirect.com/applications/category/category_slc.asp?page=2&Nav=|c:147|&Sort=0&Recs=10
The motherboard may not run both DIMMs, 266 & 400MHz at the same time. Every motherboard I have ever worked with requires the memory to be of the same type & speed, (MHz). If you do run two different memory speeds, chances are the new 400MHz will auto drop down to match the slower memory speed of 266MHz.
The site above does have both types of memory. The best buy for your money would be the faster memory. (Ultra 512MB PC3200 DDR 400MHz Memory 2 Pack, Total 1GB).
Link to your motherboard; http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=453&CategoryID=1&DetailName=Feature&MenuID=45&LanID=0
Good luck marlonpanis!
Need more information, just post.
Mike
Posted on Mar 09, 2009
    President:
  • 415 Answers
Cpu upgrade
Maximum memory for this model is 512mb, no cpu upgrade neccessary. 2 x 256mb sticks is OK.
Jan 18, 2014 | IBM ThinkPad A22p 2629 Notebook
My Mother board is ECS P4M900T-M2, im thinking of upgrading my video card into 512MB or 1GB video card. is it possible since the specs of my board says; Integrated Chrome9TM HC IGP Memory: Maximum up...
Yes it is possible to still plug-in an expansion video card. The 256MB limit is for the shared memory if you will be using your integrated Video Card. You can ignore it once you plug in the new video card.
Hope this helps.
Sep 04, 2011 | EliteGroup P4M900T-M (V1.0) Motherboard
I want to upgrade my RAM on my eMachine t3504. I currently have 256 in each of my 2 slots. Can I upgrade one of the slots to 1 GB and leave the 2nd at 256 or do I have to upgrade both slots?
Yes you can upgrade 1 of the slots to 1GB, as long as 1GB stick of memory is the 256MB stick then you can have both, to check the memory you will have pull them out of the slots and have a look on a little sticker on one side of them. You are looking for i.e DDR400/333/266 if the 1GIG memory matches one of the values mentioned above, say it is a DDR400 and the 256 is a DDR400 then they are compatable if not you will have to just leave the 1GIG stick in by it self in DIMM socket 1.
Apr 03, 2010 | E-Machines T3504 PC Desktop
I want to upgrade my PC's RAM from 128 to 512 MB Is is possible to add only single RAM or two 256 MB RAM?
Depending on your mobo, you can do either, add one stick of 512MB or two sticks of 256MB. If you're sure you get matching sticks if your mobo is DDR capable.
Jan 03, 2010 | Intel Motherboard
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Simply upgrade to more memory
G-Skill is what I put in all my custom built computers.  Search newegg.com and you will find what youare looking for.  You want PC2700 DDR.
Mar 12, 2009 | Computers & Internet
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
Choosing/upgrading DDR memory
hi there,
i dont see why u should not upgrade to 1gig RAM ... but u should stick to one memory speed ...and Size but if u can try to get the PC2700 - DDR400Mhz memory
Apr 14, 2008 | Syntax SV266A SKA KT266A Motherboard
Memory problem
Hi
Compaq Presario 700z notebook PC supports 128MB, 192MB, 256MB, 384MB PC 133 SyncDRAM (SDRAM). The Max Capacity is 384MB.
On this basis, I agree to upgrade the BIOS to support a 133Mhz (PC 133) memory module (DIMM).
At current DIMM capacity and prices, ensure the total memory capacity does no exceed 384MB. On the same note, a 512MB DIMM or two 256MB DIMMs are not supported. The best combination to achieve 384MB will be one 128MB and one 256MB DIMMs.
Compaq Presario 700z notebook PC - Product Specifications - http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00009013&lc=en&cc=us&dlc=en&product=95526&lang=en
Regards
Mike
Mar 27, 2008 | Compaq Presario 700 470024-192 Notebook
EliteGroup PM800M2 Motherboard Logo
136 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
