Question about Casio Exilim EX-S500 Digital Camera
Memory card when i turn the camera on it take
Memory card when i turn the camera on it take awhile before the camera turn on and than displays card error
  • 423 Answers
Check to make sure you...
1) have the card seated properly in the camera.
2) make sure the card your using in the camera is not full.
3) make sure if it's an SD card that it's not physically locked.
Rob
Posted on Mar 09, 2009
SOURCE: memory card error
The problem seems to be that the card has been formatted incorrectly (probably by your computer, if you used it in a card reader?). Unfortunately the camera can't reformat it itself, and default computer formatting is incompatible. You'll want to download the program Lowlevelformat.exe from this website--http://olypan.quotaless.com/forum/viewtopic.php?t=8, install it, reformat your memory card with it, and the camera will be happy with it again.
Posted on Jul 01, 2007
Nitrotrike
  • 589 Answers
SOURCE: memory card error displayed
There is a little slide switch on the side of the memory card. Good luck!
Posted on Jan 08, 2008
t00nz
  • 4738 Answers
SOURCE: S400 memory card error
The internal BIOS battery has run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Posted on Feb 22, 2009
  • 5 Answers
I assume that you know that there is a tiny tiny on-off switch on the edge of each SD card. If they are locked in the off position....
Posted on Apr 29, 2009
SOURCE: Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Posted on Jun 12, 2009
No memory card message
try another memory card and if that doesn't work you should probably go to a local camera store or the place you bought your camera
Apr 16, 2013 | Sony Cyber-shot Dsc-w610 14.1MP Camera...
In olympus fe 280 when i have placed the xd in the camera and turn on the camera then it displayed two options either to clean up or format then i have chosed format then it displayed after some time like...
A camera memory card should always be formatted IN the camera.
Do not format camera memory cards in a computer card reader.
If the card is formatted in the camera and after that the same error pops up,
you should replace the memory card and recheck.
Jun 15, 2011 | Olympus FE-280 Digital Camera
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
Turn on the camera. "Memory Card Error" displays.
You'd better change a new memory card that doesn't have a problem to check whether it is matter of Canon PowerShot A480,or use another well camera to check if it is error of your memory card.
Feb 17, 2011 | Canon PowerShot A480 Digital Camera
Oct 08, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
This is for the c713 kodak easy share, couldn't find it on the index.
YOU DIDN'T SAY, BUT I WOULD GUESS THAT WHEN YOU TURNED THE CAMERA BACK ON THE BATTERY WAS DEAD? THIS IS ONE POSSIBLE REASON TO LOSE MEMORY, EVEN THOUGH THE MEMORY CARD SHOULD HOLD YOUR DATA. YOU MIGHT POSSIBLY HAVE A FAULTY MEMORY CARD ALSO. ALSO REMOVING THE MEMORY CARD AND REINSERTING IT CAN SOMETIME CAUSE IT TO LOSE MEMORY. ALL POSSIBLES, BUT TRY USING JUST THE INTERNAL MEMORY OF THE CAMERA, WHICH IS SMALL, BUT SEE IF THE SAME THING HAPPENS DOING THIS. IF NOT, I WOULD SUSPECT THE MEMORY CARD IF IT HAPPENS MORE THAT ONCE. THEY DO FAIL ONCE IN AWHILE. THE KODAK HAS A SETTING THAT LETS YOU SELECT INTERNAL MEMORY OR SD CARD. TRY THAT AND SEE WHAT HAPPENS. IT'S BEST TO JUST GET IN THE HABIT OF DOWNLOADING PHOTO'S WHEN YOU GET BACK TO YOUR COMPUTER AND NOT TAKING A CHANCE AT LOSING SHOTS. I CARRY MY LAPTOP WHEN I'M AWAY FROM THE HOUSE FOR ANY TIME JUST FOR THAT PURPOSE.
Sep 16, 2008 | Kodak EasyShare C613 Digital Camera
No memory card on display
hi , try to connect computer via usb scan with anti virus.
Dec 29, 2007 | Canon PowerShot A620 Digital Camera
"busy" in all modes except non-flash setting on 300d
bad memory card most likely.
try reformatting card in camera.
try battery out for 10 seconds for full reset if that does not work.
may have a problem writing to card.
you can also try another card. cf i believe on that camera.
good luck.
mark
Dec 16, 2007 | Canon Rebel XT / EOS 350D Digital Camera
"Memory card is full"
This error message indicates that there is no more space on the memory card in the camera. To resolve this problem, do one of the following: Turn off the camera and insert a new memory card. Transfer or delete pictures from the memory card. Change the storage location to use the internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
"No memory card (Files not copied)"
This error message means that there is no memory card in the camera. Pictures were not copied. Turn off the camera, and then insert a memory card.
Casio Exilim EX-S500 Digital Camera Logo
62 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
