Question about Admiral AAV7000A
Admiral AAV7000AWW washing machine water constant draining
When started water turns on but but does not fill up tank, water constantly draining.
  • Anonymous Mar 22, 2009
    I am having the same problem with the same model. It seems like the pump is constantly on when it should not be. Any help would be great. Thanks.
  • donnabratt Apr 20, 2009
    I have the same problem with my Admiral AAV7000A. At first it would not run at all but would make a humming noise. Got it running but not drains out the bottom near the pump, looks like draining at pump instead into hose. Checked hoses and connections -are good. It will not even fill up but drains right out.
SOURCE: wi 101 INDEST
Switch the machine off, turn the dial to stop (end of cycle). Turn the machine on again. This should reset it hopefully. i am no expert but it will take seconds to try. Stu
Posted on Sep 08, 2007
ginko
  • 19396 Answers
SOURCE: admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
Posted on May 24, 2008
Washer_tech
  • 164 Answers
SOURCE: Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Posted on Dec 01, 2008
  • 36 Answers
SOURCE: Water overflowing from Wasing Machine AAV7000AWW Admiral
this is 1 of 2 problems. either the pressure switch is no good or the pressure switch hose has a hole in it causing the air pressure from triggering the switch. locate the pressure switch and pull the hose off the end. start the washer and try to blow into the end where the hose was connected. if the water stops then you will need to replace the pressure switch hose. if the water doesn't stop coming in then you will need to replace the pressure switch
Posted on Jan 03, 2009
falspet
  • 438 Answers
SOURCE: the washing machine only keeps filling with water never stops
there is a water sensing device in your unit that is not working, it is located at the top end of a small plastic tube cumming from the washing drum the unit will have a number of wires going to the top or side of it and the plastic tube attached to the bottom, replace this unit
Posted on Apr 28, 2010
Admiral washer aav7000aww
If your drain is not high enough, 39 inches, from the ground, it will siphon out. Also if your drain hose is too far down the drain, this will also happen. Just make sure your drain hose in not laying on the ground.
Sep 02, 2014 | Admiral Washing Machines
Admiralwasherm#aav7000aww fills up just humswont agitate
Possible that the motor is not starting up as the starting capacitor to the motor is weak. check if the motor is warm after switching off power. if so it is confirmed. Otherwise it can be due to a belt issue, bearing failure and jamming of the agitator and shaft.
check power to the motor during the wash cycle to confirm , if not the control unit is a suspect.
Jul 05, 2012 | Maytag Admiral AAV7000A
Washing machine constantly fills
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Whirlpool Clothes Washer Water Level...
My washing machine will not hold water during filling at the beginning of the cycle. It will constantly run for about 30 min to an hour. Then it will not switch to the rinse cycle. Please help???
The water is siphoning out the drain line because it is too low or is closed off at the top causing no air to enter the drain.
The drain line should be a minimum of 36 inches from the floor.
Jan 06, 2011 | Admiral AW22 Top Load Washer
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Jan 01, 2009 | Admiral AAV7000A
Water fills to overflowing without stop
replace the hose ..connects to tank other end goes under console to water level switch so no level control
Nov 16, 2008 | Admiral AW22 Top Load Washer
Admiral washing machine AAV7000AWW won't stop filling or agitate?
May 24, 2008 | Admiral AAV7000A
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Dec 21, 2007 | Admiral AW22 Top Load Washer
Admiral AAV7000A Logo
130 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
