Canon PIXMA MP830 All-In-One InkJet Printer Logo
Posted on Mar 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon Pixma MP830 error 5100
I have a Canon Pixma Mp830 error 5100, Copy button and alarm indication are now alternatively flashing, unable to use printer
Not sure where to start because dont know what the error 5100 indicates.
Anonymous
Level 3:
  • Master 412 Answers
  • Posted on Mar 09, 2009
Anonymous
Master
Level 3:
Answers
412
Questions
Helped
271779
Points
1322
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
Have a Canon MP830. in the middle of printing, it came up with error code 6A00, and now all it does is flash the alarm light and copy light. how to fix?
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830#BrochuresAndManuals
I would download the manual for windows 7 and see if the 'alarm and copy light flash' error is listed. I could not find it referred to in the support area of the canonusa.com website. Also, you could call 1-800-OK CANON and talk to a rep. about this problem.
Good luck on this repair.
2helpful
Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
1helpful
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
4helpful
Canon MP830 error code 6A00
HI,
Please the pixma off and open the lid.Now manually slide the cartridge-tray to the left.
Use a piece of tissue to clean the base-pad where the heads are stored.See if it is stuck in a kind of upward position and look if the mechanism that moves the tray is released if not then touch it and it will be loose. Remove all ink residue, move the tray back to its most right position and close everything.
Let me know if you still get the same error.
Thank you
1helpful
My MP830 has an error code of 6A00. The assembly
6A00 means the purge assembly is jammed or worn out. Part number QM2-3032-000 around
$30.00. It's the cleaning assembly on the right where the printhead parks when shut down.
6A00 ERROR
THE #1 SOLUTION FOR EVERYONE WAS CLEANING WITH WINDEX. I ONLY HAD A FOAM CLEANER AND ONE POOR COTTON SWAB AND RAGS, BUT IT WORKED. I CLEANED THE
AREA NEAR THE INK CARTRIDGES IN THE BOTTOM OF THE MACHINE. IT WORKED THE FIRST TIME!
I BOUGHT A SWAB KIT FROM CABLE AND CONNECTIONS AFTERWARDS. IT HAS SIX INCH LONG SWABS AND A SMALL BOTTLE OF ALCOHOL. kIT # 900-219 BY Pro'sKit Tools. IT SHOULD BE PERFECT FOR ON GOING MAINTENANCE.
THANKS FOR THE HELP.
STUART
old marine
old marine
ZJ Limited
ZJ Limited
