Proscan PSVR 81 VCR appears to have tracking problem
Bought used Proscan PSVR81 VCR. No manual, no remote control.
VCR was working fine. One day pulley for drive belt fell off, drive belt came lose and a tape got all unwound inside the unit. Opened unit, removed tape, put pully and belt back. The VCR mechanism works, but now cannot get clear picture.when playing tape. Audio is fine, but video have streaking lines across picture as would be when poor trackin occurs. Can't find any tracking control.
If the fast forward button is pressed, the video appears perfect at the instant just before it fast forwards. Otherwise video not working properly. Is there an alignment procedure to perform when replacing belt?
5 Suggested Answers
  • 277 Answers
SOURCE: The unit will fast forward and rewind, but won't play
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but
Posted on Nov 22, 2005
  • 883 Answers
SOURCE: My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
Posted on May 27, 2007
  • 979 Answers
SOURCE: Only plays picture when fast forward.
Cleaning or video head replacement time....accordianman
Posted on Feb 15, 2008
  • 206 Answers
SOURCE: Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Posted on Mar 07, 2008
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
My vcr PSVR 73 starts and than stops. I will pay the $35.00 if this is fixed. If not I do not want to pay
My Panasonic pv-4661 does not rewind, play nor forward a tape, it says it is locked. Any suggestions? I have tried pressing the stop button for 10 second, also tried pressing the power button for five seconds. No solution... Any suggestions will be appreciated.
Jan 13, 2013 | Proscan PSVR73 VHS VCR
How do i adjust the tracking using a remote
the TRACKING IN VIDEO VCR , you can adjust from your remote control, you must identify by reading your instruc, manual download for free. go to or
God bless you
Jul 13, 2012 | GoVideo Go Video DVD/VCR Combo
Hi. I am using a Panasonic 4 Head Hi-Fi Stereo Omnivivion to convert VHS tapes to DVD. It appears that the tracking needs adjusted, but I do not see anything on the unit to do this. Can you help?
Normally the tracking control is on the remote control. Some models do use the up & down channel selectors on either the remote or the front panel of the VCR. If you don't have the remote, the best way to test if it is these controls on the front panel, is to start a video playing a hold down the up or down key and watch to see what happens. If they operate the tracking, the tracking should go way off (do it on a video that is tracking well when first playing).
PS don't forget to clean the video head every so often (Servisol video 40 spray is best for that).
Jan 09, 2011 | Panasonic PV-V4523S VHS VCR
Proscan vcr plus gold stuck in lock
I just had the same problem and found a solution on the internet that worked. Hopefully you still have the VCR's remote control. Press and hold either the on/off, VCR1 or VCR2 button on the remote. I pressed the VCR1 button and held it for about 5-7 seconds. It released the lock and worked fine afterwards. The lock is some kind of childlock devise.
Mar 10, 2008 | Proscan PSVR73 VHS VCR
Lost remote and rca universal remote no can be programed
I used the remote control code of "69" for Thompson which makes GE & RCA according to another post. This worked to program the remote of my GO Video DVD-VCR for the TV
Dec 29, 2007 | Proscan PS27113 TV
Toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Nov 29, 2007 | Toshiba SD-V394 DVD Player/VCR
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Proscan PSVR57 remote
book instruction, 96-psvr57-001 can check RCA
Jul 12, 2007 | Proscan PSVR57 VCR
My vcr lcd reads LOCK now and I can't access any menu functions
My Proscan PSVR74 turns on, says "Hello" and immediately goes to Stop and turns itself off. Is there any hope for this machine?
May 08, 2007 | Proscan PSVR73 VHS VCR
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
