Question about Crest Audio CPX-900 Amplifier
What Crest Amplifier series replaces the VS series
  • 4,234 Answers
This is kind of an ambiuous question. Are you looking for barrier strip inputs and outputs? Are you looking for 70V output lines? Or are you looking for a standard 1/4" TRS input with either 1/4" or speakon outputs? If you can describe your application requirements, I can provide you with a recommendation.
Thanks,
Dan
Posted on Mar 09, 2009
He never active and ACL Led stays on and the cooling fan go for hi speed
Hello folks,
The same thing happening with my crest cc4000. The plastic connector, connecting the wires from the transformer to the circuit board was burnt damaged and was removed. but acl light still stays on and amp not active.
Dec 19, 2012 | Crest Audio CC4000 Amplifier
Smoke comes out from the switch and wont turn on ... there 2 amps make of ca9 and ca6 wondering if you guys can help
This is a very easy cheap fix, but since this thread is pretty old first make contact to help you out with this issue, common on CA series power amplifiers of Crest Audio.
Aug 12, 2011 | Crest Audio CA 9 2Channel Amplifier
Am a technician, i havent dealt with crest sound before. my client's amp has lit the clip light, control light but not the signal light. initially it was ok but all of a sudden, they went to operate it and...
The signal light is triggered by the presence of an audio signal on the input side and should be visible. With the clip light on without any input signal, suggests a problem in the front end. This is not an amp to be worked on without a schematic. Try getting the prints for this from Crest (Peavey owns them now).
Dan
Feb 17, 2011 | Crest Audio CA 6 Amplifier
How to activate 70v line of crest audio cki 800v
First of all the 70 volt line is used when we are dragging long lengths of speaker wires. hence to counter the drop we use a high voltage line brring it further down without any remarkable drop and use a step down matching transformer to power the speaker according to the impedance of the speaker to the secondary of the transformer. Connect the 70 volt to the 70 volt output in the amplifier. Now connect the other end of the wires tto the primary of the 70 volt transformer. Use the secondary output to connect to the speaker using the tap most suitable..2, 4,6,8 ohms . Check the phasing when you connect or reverse if the bass quality is less.
Hope this helps. Good day
Jun 29, 2010 | Crest Audio CKi 800v Amplifier
Why my crest audio ca6 has the lights clip signal
disconnect you load (speakers) power amp up. If this fault persists there might be a problemm with the amp
Apr 21, 2010 | Crest Audio CA9 Car Audio Amplifier
Every time I turn the amp on it shuts its self off.
disconnect all speakers and test if the problem corrected you will have a problem in your speakers(either wire or speaker itself)-try to connect the speakers one by one until you find the bad one and change it--if all above does not work send your amp to service center near you
Mar 30, 2009 | Crest Audio CPX-900 Amplifier
My CA9 has protect recurrent problems.
if you are bridged in parallel instead of in series the amp wont support the load so it turns the power protect on till the amp cant handle nomore then the amp will go if you have two subs bridged run them left speaker possative to to the amp possative for bridged mode then laft speaker negative to the right speaker possative then right speaker negative to your amp negative for bridged mode if you have them left and right speaker possative to amp possative and left and right speaker neggative to your negative to your amp thats parallel the ampwont support the 2 ohm load
Feb 08, 2009 | Crest Audio CA9 Car Audio Amplifier
No power
These amps are very compact and are not the easiest to work on. If you are not experienced at repair, I would not recommend you start here. Where are you located?
Dan
Jan 13, 2009 | Crest Audio CPX-900 Amplifier
Crest Audio CPX-900 Amplifier Logo
171 people viewed this question
Top Crest Audio Audio Players & Recorders Experts
Owen Barnes
spacil
spacil
Level 1 Expert
Are you a Crest Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
