Question about Microsoft Press MS Access 2000 and Visual Basic for Application (0-7356-0592-0)
What is the compatible database for visual basic 6.0?
It is about the compatibility of data object of visual basic 6.0 and the database created in MS Access 2000
    Scholar:
  • 145 Answers
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Posted on Mar 12, 2009
Access database 2003 problem with a copy of database file. How to fix?
You say corrupt, in what way exactly? Do you get any specific error numbers/messages?
Have you tried Access repair program? Compact and Repair. If not, use it. But ensure that you made a backup, it is necessary because all the recovery tips can make the damage even worse.
Also try Jet Compact Utility. This tool created by Microsoft and it is much like Compact and Repair, but more successful in repairing.
If no one of above advice helps, then perhaps you need more powerful solution. In this case try to run a good third-party. I would recommend Recovery Toolbox for Access. It must help you. https://access.recoverytoolbox.com/
Feb 23, 2015 | Microsoft Access 2003 for PC
Access 2007 corrupted database
You may try this third party tool programmed with best technology the tool support all windows and MS office versions. You may try free demo version of this software to preview your recovered access database. SysTools Access Recovery you may check How tool works and its user friendly interface make this easy to handle.
Jan 11, 2015 | Microsoft Office Professional 2007 Full...
Please give me the procedure how to import foxpro files in tally 7.2
To import data from a FoxPro database, use the Microsoft Visual FoxPro ODBC driver. To do so, follow these steps:
1) Click Start, and then click Control Panel.
2) In Control Panel, double-click Administrative Tools.
3) In the Administrative Tools window, double-click Data Sources (ODBC), and then add a new ODBC data source for your FoxPro database or tables by selecting the appropriate Visual FoxPro driver.
4) Start Access, and then open your Access database. 5) On the File menu, point to Get External Data, and then click Import. 6) In the Import dialog box, click ODBC Databases in the Files of type list. 7) In the Select Data Source dialog box, click the Visual FoxPro data source that you created in step 3, and then click OK. 8) In the Import Objects dialog box, click the tables that you want to import, and then click OK.
Jul 05, 2010 | Computers & Internet
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
May 31, 2010 | Microsoft Visual FoxPro Professional...
Visual Basic and SQL
Visual Basic 6.0 and MS Sql server 7 or 2000 are highly compatible with each other. VB.net is compatable with sql 2005 which is inbuilt as well.
Jul 07, 2009 | Microsoft Windows Vista Ultimate Edition
I want to programaticaly modify an SQL statement in VB6
If I remember correctly you need to call ExecuteQuery or something similar otherwise it does not update the database.
Regards
GeWiz.
Jun 16, 2009 | Microsoft Visual Basic Enterprise Edition...
Microsoft Access 2003 crashes on ''Compact and Repair''
Your best bet would be to repair your office installation in Vista. Regards -- Joe (Access VBA Examples)
Nov 10, 2008 | Microsoft Office Outlook 2003 for PC
About visual basic coding
The standard way of creating a database using VBA, which can be modified to suit your needs is this--> Note: the code (wspDefault.CreateDatabase("Newdb.mdb"...), can be altered to save the database in a folder  such as "C:\NEWDB\text.mdb". sub NewDatabase()     Dim wspDefault As Workspace, dbs As Database     Dim tdf As TableDef, fld1 As Field, fld2 As Field     Dim idx As Index, fldIndex As Field     Set wspDefault = DBEngine.Workspaces(0)     ' Create new, encrypted database.     Set dbs = wspDefault.CreateDatabase("Newdb.mdb", _         dbLangGeneral, dbEncrypt)     ' Create new table with two fields.     Set tdf = dbs.CreateTableDef("Contacts")     Set fld1 = tdf.CreateField("ContactID", dbLong)     fld1.Attributes = fld1.Attributes + dbAutoIncrField     Set fld2 = tdf.CreateField("ContactName", dbText, 50)     ' Append fields.     tdf.Fields.Append fld1     tdf.Fields.Append fld2     ' Create primary key index.     Set idx = tdf.CreateIndex("PrimaryKey")     Set fldIndex = idx.CreateField("ContactID", dbLong)     ' Append index fields.     idx.Fields.Append fldIndex     ' Set Primary property.     idx.Primary = True     ' Append index.     tdf.Indexes.Append idx     ' Append TableDef object.     dbs.TableDefs.Append tdf     dbs.TableDefs.Refresh     Set dbs = Nothing End Sub
Hope this helps! Please let me know if you have any questions.Thank You,Raph30
Apr 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Coding in ms word by using visual basic editor
Hello Kavita! If you want to get the most of VB then i advice that you install Microsoft visual studio...But just in case you want it for free you can find it here..
http://www.brothersoft.com/downloads/vb6.html
Nov 10, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Linking vb to access
You post it in the wrong product, you should have posted it in Access or Office. But I will try to answer anyways...
In tools look for references and then look for MS ADO Data Control 6.0 or Microsoft ADO... Just select it and press ok then you will have a new control object name "ADO data control". See the explanation about the ado data control which is very easy to use...
Here is also a great tutorial for the ADO Data Control:
http://www.devarticles.com/c/a/Visual-Basic/Implementing-An-ADO-Data-Control-With-VB6/
You can also use VBA in Access, you have exactly the same functions there as well.
Sep 19, 2007 | Adobe Photoshop CS2 for PC
Microsoft Press MS Access 2000 and Visual Basic for Application (0-7356-0592-0) Logo
293 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
