Question about Alesis Sr 16 Stereo Drum Machine
All seems working but NO sound coming out of any outs. I've initialized it and did all I can remember to get it up and running after a long rest... in other words, it's been in the cupboard for some time... Thanks in advance Guy Units powers up, screen lights, and readouts change. Buttons make changes (tempo up/down, selects different presets, etc) but no sound. Not from any of the four outs, using different cables to different amps etc. I reinitialized it - no change. Help?! James
    Brigadier General:
  • 3,614 Answers
HI THERE,
CHECK ALL CONNECTIONS POSSIBLE LOOSE CONNECTIONS.
CHECK THE SOUND VOULUME WAS NOT SET TO MUTE
Posted on Mar 09, 2009
Marshall Amp Quit
According to the schematic, once the signal is initially amplified (also where the LED shows signal), the audio is sent to the send/return jacks (shown on pg3-C7). A quick test to see if audio exists at the insert point will require an insert cable. An insert cable can be a balanced 1/4" cable which splits out to two mono 1/4" connectors or a pair of RCA's. Connect one of the insert outputs to a console (if 1/4" cable) or a tape loop on a home stereo receiver (if send cable splits out to RCA's) and see if you've got sound when playing your guitar (with LED on the Marshall showing signal). If no sound, go to (A) below. If you have sound, go to (B) below.
(A) Ten pin connector labelled CON2 (shown on pg5-B1). Make sure connector is tightly seated and that the pins on the jack and the female connectors in the plug are clean and that good contact is being made.
(B) Twelve pin connector labelled CON1 (shown on pg5-B4). This is the DFX board - make sure this is tight and well seated.
According to the schematic there are voltages seen at several of the connection points previously mentioned. If you have a multimeter and are qualified and careful - check to make sure the voltages are present as shown.
If you're not qualified - meaning you have little or no experience - STOP and refer this repair to a qualified bench tech. They get paid to keep the magic smoke inside the amplifier. You may end up damaging things worse or even beyond repair or even damaging yourself.
Nov 12, 2013 | Marshall Amplification Marshall MG250DFX...
I have a peavey triflex first addition hooked to peavey pv14 mixer everything works great till I turn the volume down then the subwoofer stops working the power is on but nothing at all coming from it it...
Your sub may have one of those annoying circuits that turns it on in accordance with overall signal level. Supposed to act as a subsonic filter.
Aug 24, 2017 | Music
Need repairs on Technics SX-PX103-M Model.
Have you had any luck with your Technics piano? I've got the same piano and Mine does not work either. No lights on the control panel, only red power light comes on. Does yours have any led lights besides the power light that come on? I've investigated and I have learned a lot from this piano. 4 main boards. Im pretty sure I've got it down to one board. Interested in selling me any boards from your Piano??
Jan 19, 2012 | Music
Marshall mg100hdfx head. I get no sound whatsoever plugged into the guitar input but the controls seem to work as I can hear changes in the light ambient static. I will get sound however if I plug directly...
You MAY have a broken input jack. If you can hear changes from the overdrive gain control, that control is just one stage away from the input jack. Also there is a capacitor C60 that is for RF bypassing and if that shorts that will kill the audio. Yes, inout jacks get destroyed by tripping over guitar cables... that is why you run the cord through the amp handle before plugging it in. Of course verify your guitar and cable is good using another amp.
Aug 30, 2011 | Music
I have a Williams Encore Digital piano. When I power up there is no sound. Upon power up there are 8 small rectangle on the LCD screen. 7 red light are lit. They are the 4 lights above the "user...
Holding the page up and down buttons while powering on supposedly resets it. I have no sound except demos, but no lights showing like yours, and williams tech support said to reset that way but it didn't seem to do anything. Good luck hope this helps!
Jun 27, 2011 | Williams Encore Digital Piano
Turned on studiolive, initiated Capture program, started the capture demo session. No sound out of mains. ALL channels panned right and all fat channel settings identical. I cannot recall a saved...
isnt this the newest Presonus out there. maybe its a bug. it seems like its own but nothings working. i would call them and have them troubleshoot, Prosonus has a Ton of things that could be causing it.
May 13, 2011 | PreSonus StudioLive 1642 Mixer Digital
I'm using an external reverb (T.C. Electronics Nova) through the effects loop and I can only get verb out of one channel (left I think) and in fact it seems that the "stereo" section (knobs etc.) have no...
The external effects when used would require an effect processor with left and right channels. You need four cables total for the effects... the two channels out to the effect unit and two cables to bring it back to the power amps.
Remember to use your pan controls if you want certain inputs to go more to either the left or right outputs.
Oct 15, 2009 | Fender Passport Deluxe 500watt Sound...
I have a Mackie cv1604 which suddenly stopped working. all lights on the channels light up and no sound. help?
same problem here.. gimme a holler if you've figured anything out.
mine, channels light up, it's getting sound (input) from mics, but it's no sound coming out. i'm almost definite the problem is with the main mix slider. but then again i could be wrong.
Jul 10, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
All seems working but NO sound coming out of any outs. I've initialized it and did all I can remember to get it up and running after a long rest... in other words, it's been in the cupboard for some...
If I remember correctly it will have a backup battery inside that may have died. You will need to replace it and download the correct patch to get it up and running again.
Feb 20, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 Stereo Drum Machine Logo
193 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
