Question about Samsung LN32A330 32 in. LCD TV
My tv want come on ? i cut it off and it want come backon
    Sergeant:
  • 280 Answers
Probably bad or leakey capacitors in the power supply. A good tech can replace the puffed up and leakey ones rather than replace the board.
Posted on Mar 13, 2009
Need recovery disk for hp mini 2140
Hi
you could try this if it helps
There are two ways to access Roxio BackOn Track to recovery the computer, either through the boot menu, or through the Windows Start menu.
    You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored.
    1. Press the power button to turn on the HP Mini.
    2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.
    If you can access Windows, in addition to restoring your computer to a previous working state, you use other options, such as Disaster Recovery.
    1. Click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track
    Hope this helps you
Aug 19, 2011 | HP Mini 2140 Notebook
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
LCD TV Problem
Replace Lamp in TV and lamp replacement procedure would be written in Instruction Manual of TV.
Always buy Sony Original Lamp for smooth picture result and avoid aftermarket/ cheap lamps.
Let me know exact model number of TV if you need more help.
Apr 22, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Tv shuts off wont come backon samsung fpt5084x
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Mar 06, 2009 | Samsung FPT5084 50 in. Plasma HDTV
How do i get the backlight to go on again on my m240 sansa scandisk? thanks
On my C100 the backlight comes backon when I press the menu button.
Hope that helps.
Honestly.
Dec 01, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
I have a Pioneer Pro510HD 53" Pioneer Elite TV purchased in late 11/2001. Not heavily used. The set,working great..suddenly shut down with a snap. Now will not power up. It does have power, red light...
For $15.00 Premium Information Plan.....I WILL TELL YOU HOW I DIAGNOSED/ADDRESSED THE ISSUE AND COMPLETELY RESOLVED THE PROBLEM !
thanks....and I do accept credit card...... John Presson
Oct 10, 2008 | Pioneer Televison & Video
DRIVE BELT ON HOTSPOT WASHING MACHINE
my hot spot washing machine write f12 and it woud start do you have solution to this problem please
May 15, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Samsung LN32A330 32 in. LCD TV Logo
112 people viewed this question
Jerry Greenberg
Jerry Greenberg
