Sony DVD Creative CD_RW
Both my CD and DVD stopped working. The computer does not recognize they are there by assigning a drive letter.
I have a code 19 error.
I used Article 314060,320553,and 310426 to solve the problem.
I requested premission for full control at regedit32.exe,and tried to edit \ delete:
HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS\{4D36E965-E325-11CE-BFC1-08002BE10318}
the system would not allow me to delete. I tried several times.
I am current on my XP updates! Was working but just stopped and I had not just installed XP. I have been having problems with the computer cutting off all the time with C4 and A errors!
How do I solve this problem!!!!!!!!!???????
5 Other Users Have The Same Problem
Comment by vdolby, posted on Jul 22, 2008
i cant able to find the cdrom in my system its not detecting
Comment by Al Khameri, posted on May 19, 2008
my sony vgn-s48gp cd-rom does not operate dvd
Comment by Guest, posted on Apr 03, 2008
hp dvd drive error code 19
Comment by DJG3, posted on Dec 27, 2007
I have a HP Pavillion that is giving me a Code 19 and referring to a incorrect entry in the registry. What needs to be modified for this problem to be fixed?
Thanks
Comment by Guest, posted on Dec 05, 2007
teac dw-24e-b
Rating: 0%, 0 votes
Use that file provided there.
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
31, Code 32, Code 19,
#. The file
would not delete. I see no patch!!
19, or Code 39 After You Remove Easy CD Creator in Windows XP
Before you modify the registry, make sure to back it up and make sure that
you understand how to restore the registry if a problem occurs. For
information about how to back up, restore, and edit the registry, click the
following article number to view the article in the Microsoft Knowledge
Base:
software from your computer, your computer may exhibit the following
behavior:
any CD-ROM device that is part of your computer system:
required for this device (Code 31).
driver is corrupted.
that the registry returned some unknown result:
find the hardware device. (Code 41)
problems that may require you to reinstall your operating system. Microsoft
cannot guarantee that you can solve problems that result from using Registry
Editor incorrectly. Use Registry Editor at your own risk.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11C
Lowerfilters value, if you notice lost functionality in a particular
program, such as CD recording software, you may need to reinstall that
software. If the problem recurs, consult with the software vendor for
assistance.
version 5.01 or earlier or DirectCD version 3.01c or earlier. This issue may
also occur with Easy CD Creator version 5.01 and with DirectCD 3.01d or
later.
similar behavior. Some or all of the troubleshooting steps in this article
might apply if such a product also adds entries under the UpperFilters or
LowerFilters value in the registry, either by adding its own filter drivers
or by removing the registry keys and values outlined in this article that
begin with:
making any changes. The third-party products that are discussed in this
article are manufactured by companies that are independent of Microsoft.
Microsoft makes no warranty, implied or otherwise, regarding the performance
or reliability of these products.
& Privacy Accessibility
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
See the second "problem" (read the caveats)
Run the provided registry patch
That should fix your problem (basically, a filter driver is missing or
non-operational, the registry patch will delete the filter drivers
references for your cdrom(s))
Basically, the reg file from above carries out the steps displayed at this
website
CD-ROM Drive or DVD-ROM Drive Missing After You Install Windows XP
CD-ROM Access Is Missing and Messages Cite Error Code 31, Code 32, Code 19,
(It'll fix code 41 errors too as per the contents of the last kb article)
