Question about Boss AUDIO SYSTEMS BV7985 Car DVD Player
Boss bv7985 im trying to install the boss bv7985 into a 2002 ford mustang. i have the wireing hornest in place and hooked to the boss dvd system. when i put a dvd in i hear it but i cant see it on the display. wat am i doing wrong?
  • 94 Answers
There should be a wire they wanted you to hook to the parking brake as a safety feature so you cant drive and watch tv. but you can just take that wire and ground it to your black ground wire on your radio that should give you your pic
Posted on Mar 09, 2009
How do I find out what make, model my 302 engine came out of ? It's in my '66 Mustang. I was told it's a '71 motor, but I would like 2 know what make, model ex (LTD, Maverick, F-100 Pickup) etc.?
Try taking the number off the engine and see if the dealer can search it up. I doubt they only put it in one car model, but the number on the engine should match the frame. Get where I'm going? As old as it is, I wouldn't expect anything though.
Apr 29, 2016 | Ford Cars & Trucks
Boss diagram
the 2 power lines to supply batery and black to ground blue to speaker
Jun 07, 2014 | Computers & Internet
2002 mustang the motor turns over and it gets gas but it wont run gas had water and we empty it and put new gas but it want run
Fuel system may be contaminated. Even if you drain tank it will have water in the injectors. Take a can of starting fluid, have some one turn over engine. Spray a small amount in throttle body. IF engine starts suspect water still in injectors. You may have to repeat several times to clear out. ALSO there is a small valve on fuel line. IT is where you would hook a fuel pressure gauge. YOU can bleed the water out at that point. You can open valve and turn key on and off several times, place a rag over check valve as fuel will spray out! Close valve try and start car
Feb 16, 2011 | 2002 Ford Mustang
Headlights on my 65 mustang wont work......the plug for the headligths tests ground on one and the other two nothing, not sure how to test the switch to see if it is good or not
get you a light tester groud it to the battery stick it in each hole see if it lights up if it dont it could be your light switch,if none of your head lights are working there could be a short in your wiring hornest, try doing your bright lightscould be your dimmer switch all kinds of things proccess of alimination
Jan 24, 2011 | 1965 Ford Mustang
I have 2002 cwrn vic and i bought boss 7300 i got all speaker wire hooked up..were i hook up battery yellow cord and trouble with making shure im doing this right..
Yellow wire should be hooked to the constant hot wire in your dash. If you check your wires with a multimeter (if you have one), with your key out of the ignition, you will find it....Only one should have voltage when key is in off position.
Oct 07, 2010 | Boss AUDIO SYSTEMS BV7300 Car DVD Player
How do you disable a theft system on a 2002 ford mustang
Take it to the ford dealer, It costs whatever they charge an hour to hook up the computer, But they can disable the pats system for you. If your in ohio i can do it
Jun 12, 2010 | 2002 Ford Mustang
Can't finish installing need help
be carfull sounds like airbag therse proceders to disarm that system all cars are different call dealer or consult shop manual.
Mar 10, 2010 | 2003 Ford Mustang
Boss AUDIO SYSTEMS BV7985 Car DVD Player Logo
318 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
