Question about Envision Computers & Internet
I need an envision monitor drive, its a RH 1450 discontinued mod
Coud any body tell me where can I find it or send me the driver? Thanks
  • Bader Mar 09, 2009
    Tks but i this exe theres no driver for rh 1450
    NO no no my friend, I need a driver for Win 98 to a monitor envison rh 1450, this is my problem. I m reparing a old pc with celeron 533 mz 250 Mb ram and I dont know what kind of video card it has.
    President:
  • 415 Answers
Follow the link below
http://208.109.129.152/support.asp?EPage=support&SMenu=driver
Let me know if it helps.
Mark
Posted on Mar 09, 2009
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Sep 21, 2011 | Envision Computers & Internet
My laptop LCD screen is FUBAR and in order to use my computer I have hooked it up to an Envision 19" LCD Monitor. If I start Windows Vista in Normal mode , it does not recognize the Monitor. Pressing...
I would go ahead and boot into safe mode where you say it does work and then take a look. See how it detected it...ie look in device manager and see if it picked it up by it's true brand/type etc. Check the settings both of the display and on the envision itself. Check the resolution selection. It's probably picking it up as a lower res. but when it boots into reg windows may be trying to run at full res and perhaps that's what it won't do. Check to see what driver it's using. It may need the specific driver from envision and not the generic driver. It could also be a bad pin on the envision itself.
If you have another computer you can hook it up to, do that to make sure the envision is working. That way you can deduce which is the problem, the monitor or the setup in your laptop.
Jul 10, 2011 | Envision 19" Widescreen Flat Panel LCD...
I need Vido driver for win 7
Good luck on that one, As with Vista many companies were left out of the loop Envision being one of them! Keep petitioning Envision to get one out to suit
Thanks for using FIXYA
Nov 20, 2009 | Envision Monitors G2219W1
I WANT DIRVERS BECAUSE I HAVE LOST THE CD ,MY MODEL NO. FC - QINGHAIHU M2VH-RH ,SO PLZ.SEND THE DRIVERS URGENDTLY,& TELL ME HOW TO INSTALL DRIVERS. THANKS
May 04, 2009 | Foxconn 661FX7MI-RS (661FX7MIS)...
Envision 19" widescreen
You can go to the Envision customer support website and look for the driver under the driver support section for you model monitor. The website is. www.envisiondisplay.com. You can also call the Envision customer support at this telephone number. !-888-838-6388. They should be able to help you with getting the correct driver to support your set-up. I hope this information helps you with your problem.
Dec 27, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Can't get sound to play on my AOC LCD from my XP computer.
did you have an installation disk?? If so it may not have loaded in the setting to make the sound card accept the monitor..Or simpler--is the right wire plugged into your computer for the sound??
color codes don't always match for generics.
Oct 12, 2008 | AOC A15X221 15 in. LCD Television
Envision EN 7100si LCD 17" flat screen
First try auto-adjust with the auto button on the screen
if not worked
Make sure she installed the envision driver. I jus saw it's a discontinued product. Also this product has a maximum resolution of 1280 x 1024.
If installed check her resolution. Right mouse click on desktop>properties>screen. Try alternate resolutions and see what happens but don't set it higher then 1280 x 1024 if possible.
Nov 28, 2007 | Envision EN-7100e 17" Flat Panel LCD...
Computers & Internet Logo
82 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
