Question about Garden
I have a lawn man mower. 6.5 hp b+s motor ohv. when it starts up ,its in full throttle. I dont see any adjustment to slow it down. It eats up the gas in the carb faster than it can be replenished, and dies. If you wait 20 seconds and try it, it starts up , and same thing. And it only runs for about 30 secs. bill
  • Keith Dickerson
    Keith Dickerson Jan 06, 2014
    Sounds like a governor problem. If no one messed with any springs or rods on carb or throttle adjustments then it's internal. Governor is inside motor casing and may have come apart as the gears that drive it are plastic. Also check carburetor throttle shaft to make sure it's not stuck and works freely. You be able to throttle down motor at carb with moving the throttle shaft.
  • 40 Answers
Sounds to me like you have governor problems. you may want to take that to a shop.
Posted on Mar 11, 2009
Why does my 6.5 hp kohler lawn mower keep pulling oil into carb air filter
Its to stop the dust blocking the filter. The filter should be cleaned with petrol every 4 to 6 months to remove the dust & oil build up, cleaned in/with petrol and re-oiled. Its also good to clean the filter housing each time you clean the filter
Sep 26, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
2008 yardman lawn mower 13.5 hp. has a high idle speed and does not slow down, need diagram for throttle control
Throttle cable should pull a SPRING, which pulls the governor, which pushes/pulls the carburetor butterfly valve.
Aug 12, 2014 | Yard Machines Garden
How to repair throttle cable on mower
You didn't state what the problem with the throttle cable was. Is it stuck in place, did it break off, did the handle break, etc.
Give some more details and I can probably help you. If you don't know the terms, that's fine, just describe it as best you can.
Jun 25, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
How do you adjust throttle cable on yardman push mower
If there is excess slack in the throttle cable, you can do 1 of 2 things. Either replace the cable, as over time it gets stretched out. Or you can look by the throttle and you should be able to slightly screw out the set screw and take a little slack out and then tighten the screw back up. If there is anything more I can do, let me know. Thanks.
The mower is running really slow
your throttle spring may have stretched out try adjusting it
Jul 16, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I charged the battery and there's gas in my lawn
Usually there is a combination choke on the throttle, when you put the throttle all the way up it sets the choke and once the engine fires you idle it downa little to full throttle.
Apr 09, 2010 | Garden
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Sep 06, 2009 | Garden
Snapper hi vac. briggs and straton 6.0 hp motor
Hey Tyson..my name is Keith..i cant help you with the fuel economy..but it sounds like your throttle cable outer casing has slipped ..so inspect it and and see if you can adjust it and tighten it down to where the throttle will work correctly..i hope this has helped
Jun 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
