Cd-rom tray won't open - Computers & Internet
  • 643 Answers
Well, it seems that your cd rom going to "retired".... U should change another one....
In case u have cd inside, there is a small hole on the cd rom front side, where u can insert a pint inside the manually open the tray...
Posted on Mar 09, 2009
My cd rom drive has power but when you try to eject the tray it won't go laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
The cd tray on my computer will not open
use thin and long paper pin to open it,
insert pin in cd tray"s hole which u see in front of CD tray and push it,you will get the Cd tray out..
May 28, 2011 | Computers & Internet
Cd rom is not working when i put a dic in it won;t do anything
Check that you have electrical power to the drive, i.e., push the button to open/close the tray.
Check that the "data" cable from the motherboard to the back of the drive is tightly-connected at both ends.
Or, spend $40, and buy a brand-new, CD/DVD, reader/writer, in order to replace the "dead" device.
Aug 28, 2010 | E-Machines emachines (emachinees) CD-ROM...
LG CD-ROM not ejecting the tray
you need a a small object...
do you see the small hole in the front of the cd rom??/you need to hit it so that it will open...
try it first...
hope i've help you.. rate me,..
Feb 06, 2010 | Computers & Internet
The CD ROM Drive is not ejecting properly
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
CD driver stuck
In the front side of the dvd drive you will see a small hole to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
The cd-rom door not open
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
Dec 04, 2007 | LG (CRD-8400CB) CD-ROM Drive
Cd rom
its very simple .remove the outer cpu case.then remove the cd rom open itplace THE TRAY in RIGHT MANNER ONCE AGAIN . donot try to move the tray of your cd rom without opening the cd rom ,it might result in a permanent damage
Nov 03, 2007 | Packard Bell GCD-R580B (gcdr580b) Internal...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
