Question about Whirlpool Washing Machines
Hi i have a whirlpool wf665-1
Hi we have a whirlpool wf665-1 frontloader when we wash our whites. They come out dirty with big dirty patches.It does matter if it half or full load. We have changed washing power twice and we have cleaned out all filters and hoses. The machine is 3 years old. Everything else works fine. Please someone help us!!!
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
  • 240 Answers
SOURCE: Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Posted on Apr 26, 2009
SOURCE: My Washing machine stains clothes;
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Posted on Apr 12, 2010
  • 1417 Answers
SOURCE: F 12 whirlpool 6 th sense washing machine.
hello,
simple ,The "F 12" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you need to do to fix up your washer is to check on the wiring connection from the power supply to the water temperature indicator.
thank you and thanks for using fixya.
Posted on Jun 01, 2010
Testimonial: "thanks it worked"
beltronic205
  • 1474 Answers
SOURCE: Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Posted on Jun 04, 2010
How can I unlock the door on whirlpool frontload duet washer
First thing is to unplug it and see if it resets. If not then you need to drain it by hand. You do this by removing the panel under the door and looking for a big pipe plug. Be advised that you will get LOTS OF WATER when you take the plug out.
Jul 25, 2015 | Whirlpool Washing Machines
How do I clean the pump on a Whirlpool 6th sense frontloader
The pump filter is situated behing the white plastic kick strip on the front at the bottom of the machine.
Instructions for use Whirlpool UK
Sep 19, 2014 | Washing Machines
My whirlpool frontload washer does not have enough water to wash or rinse properly
1. do you have limescale in your source water, if yes you need to clean your machine with a special product that can be found in the market.
2. pressure sensor is broken
3. inlet filter is dirty you can unscrew the inlet pipe and look for a small filter and clean it.
Mar 24, 2014 | Whirlpool Duet 4.0 cu. ft. Front Load...
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool frontload washer with model number WFW83005W00 and I have an error code F21 that flashes and then the washer stops working. What does this mean and what should I do?
Means the drain is taking too long . Most likely that the drain sump filter is blocked. Remove the lower front panel and unscrew the large white thumb screw attached to the pump. Water will come out so collect it then clean and replace.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Can you put a patch on the rubber gasket of a frontloader? the hole is just above the drain hole by the front door.
Try using bicycle inner tube repair patch, because it has the same flexibility as the rubber gasket on door, make sure rubber on door is clean and dry before applying rubber patch
Nov 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
My whirlpool duet sport frontloader wont drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 04, 2010 | Washing Machines
Cleaning rubber door boot
I am not sure how the Whirlpool rubber boot is constructed but the Maytag's can be pulled back enough to get a sponge, washcloth, etc. around it to clean it. If you can get to it try a product like odorban which will clear up any mold, mildew & icky smells without harming the rubber itself.
Mar 03, 2010 | Whirlpool Washing Machines
Asko front load washing machine
When u use front loaders you normally don't need a soak. And i don't think you need bleach. Use front loading powders for the machine. The automatic machine is supposed to work for you. The water empties out, so you can open the door.
Rate me pl if helped..............
Jan 24, 2008 | Asko W6221 Front Load Washer
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
