Question about Kenmore Dryers
Electrical plug is not attatched
.dryer has no electrical plug. need wiring schematic
  • 1,122 Answers
3 wire setup, middle wire goes on the middle of terminal block,and one wire each on each side of it,4 wire setup white wire goes to middle of terminal block ,red and black goes to does not matter which side(both 120 volts) goes on each side of block,the green wire gets mounted to the cabinet,it is the extra ground-mike
Posted on Mar 10, 2009
Help took control plugs out and didnt get clear pic of where one wire plug belongs need a schematic
Bottom panel. But you shouldn't be able to put harness connector in the wrong terminal. The normally all have their own special cut in the board or they will be color coded.
Jul 15, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Attatching new heating element
you have to order a new element. and take back and side panel off, to reinstall new one, what ever you do do not cut any wires.
Oct 29, 2012 | Indesit IS70C Electric Dryer
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
I need a circuit diagram for a Maytag DE212 Electric dryer.
There should be a service manual attatched to the inner cabinet of your dryer. This includes wiring diagrams.
Nov 29, 2010 | Dryers
One of the wires from the main wiring connection is burnt. How do I get to the terminal block inside the dryer where the wire is attatched to to replace it?
LG recommends replacing the entire wire harness when this happens. The burnt wires usually happens when the connection was not properly tightened. You will require a qualified LG tech to get it repaired properly.
Good luck.
Sep 21, 2010 | LG DLE2532W Electric Dryer
New plug changed from a 4 wire to a 3wire,won't run.
You have 3 lugs to hook up to. right lug gets red or black, left lug gets red or black. Center lug gets white. you can also hook green wire to center with white. Or hook green to the screw for the lug cover. What you did is correct.
Jun 14, 2010 | Frigidaire GLEQ332A Electric Dryer
Frigidaire electric dryer feq1442eso melted bracket new bracket doesn't have the same colored wires. Need schematic for wiring.
There should be a schematic inside of the back panel or inside the control panel(where timer is)
Feb 22, 2010 | Dryers
Looking for dryer diagram
There should be a schematic on the inside of the back cover, sometimes it is located in the top control panel somewhere(timer panel)
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Cord was removed and i lost booklet for re-attachment
dont have a schematic, but the cord has 3 wires,of the three wires the middle one is the important one, it MUST be attatched to the middle post connector at the rear of unit. either end can then be attatched to either end, nthey can bbe switched, its only the middle one the will need to be mounted to middle
Nov 15, 2008 | Kenmore Dryers
Dryers Logo
57 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
