Mitsubishi heatpump not blowing out heat.
Mitsubishi heat pump, model number msz a18yv. Is not blowing out hot air. What could be causing this please?
  • 400 Answers
One reason could be a shortage of refrigerant. Another could be incorrect mode selection? Or the reverse valve which changes the unit from cooling to heating is either not being energised or may be blocked and would have to be replaced.
Posted on Mar 09, 2009
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Oct 15, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
How to use mitsubishi heat pump remote
i have a mitsibishi heat pump which i purchased 2years ago but have missed place the instruction manual are you able to help me with this. the problem i am having is setting the right temperature and function that i need.the model is msz-ge5ova, thank you
Jun 02, 2012 | Mitsubishi MSZ09UN Air Conditioner
I have an air conditioner Mitsubishi MSZ-A26YV, it has stopped heating, even if it's on the heat setting [sun emblem] and is set to highest temp, only cold air comes out, otherwise it does all other...
It's not indicated to turn directly from cooling mode to heating mode. You must wait about two or three minutes before the change. After the spliter start, you must wait few minutes to get hot air.
Mar 30, 2011 | Mitsubishi MSZ-A24NA Split System Air...
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Mar 20, 2011 | Mitsubishi MSZ09UN Air Conditioner
I have a Mitsubishi mini split system heat pump model MSZ-A12NA. The problem is the wireless remote has been lost. How do I get another one? Or, can a regular hard wired heat pump thermostat be used? I...
just lift the filter panel on front of indoor unit and turn it on manually,remember this just sets the a/c to 24 deg,the unit decides whether to heat or cool it to 24 least it gets it goin so u can order a replacement
Feb 21, 2011 | Mitsubishi MSZ-A12NA Air Conditioner
MSZ-A26YV only blows air now, (no heating or cooling), no error indication. Worked all fine one day then few days later stopped. Emergency switch does the same. Looks like the external unit fails to pump...
try to check your compressor if working if not check electrical parts like capacitor. overload if defect replace. also try if compressor working observe the condensing unit fan blowing hot air if not theres possibilities of leakage of refrigerant gas need for braze leak then recharge refigerant gas. or possible compressor loose compression need for replacement.
Feb 12, 2011 | Mitsubishi Heating & Cooling
Does not blow cold or hot air
Haved you cleaned the filter?? Clean them! It might be out of refrigerant. Have the unit professionally checked.
I take the time to help, so please rate me!
May 30, 2010 | Mitsubishi MSZ-A24NA Split System Air...
The heat is not getting hot and keeps turning off
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
Jan 31, 2010 | Mitsubishi MSZ-A15NA Split System Air...
Heating & Cooling Logo
1,112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
