Question about Canon Rebel XT / EOS 350D Digital Camera
Auto focus does not work in creative modes
If I depress the exposure button 1/2 way and press the *AE button, camera will focus
Camera is Canon EOS Rebel XT 350D
  • 38 Answers
That is a custom function of the camera that can be change back to default with ease. While in one of the creative zones press the menu button and navigate to the 5th and final tab on the top right. Auto focus does not work in creative modes - 8f5da8f.jpg
This is the Setup menu 2. In this menu, select “Custom Functions (C. Fn)” . This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. 7528356.jpg
That should get your camera back to the expected auto focus with the shutter button.
Posted on Mar 09, 2009
SOURCE:
Hi there. i owned a Canon EOS 60D model camera. The problem is, its AF option is not working except Auto n 'C' modes. While i am trying to use it in M mode with AF, its not working but in auto mode an
Are you sure you did not put the AF/ MF switch in the wrong position? Although I don't think it would focus in Auto mode. In all other modes, are you sure you selected a (or more) focus point(s) in the centre of the frame?
When the selected focus point is on the side of the frame it won't focus on the parts you want it to focus. Then while pointing to the point you want the camera to focus, please press the shutter release button half and what till it focusses. Then press it the whole way down. Be aware the camera needs enough light to focus and certainly can't focus with a lens wit a min aperture of 6 or a larger number. On your 18-135 you can shoot at f16 because it will first focus on wide open and only close the aperture after you pressed the button.
Jan 27, 2015 | Canon EOS 60D Digital Camera
I try to focus and it tells me this function is not selectable in the current shooting mode
Yes there are two zones of selection on the mode dial. one is basic zone (in which you have potrait, landscape, closeup, sports, night portrait & flash off) these are fully automatic modes and the camera does every thing for you you cannot change the focus. you can zoom out and zoom in and when u see in the view finder the picture is blur. then press the shutter button halfway the camera automatically zooms in or out for the correct focal lenght. only in creative zone you can do it. like programe ae , shutter priority , aperture priority , manual exposure. Hope this solves your problem. Prashanth.
Jul 27, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
How is change shutter speed for canon 350 D camera.thankyou i am from india.
In either Tv or M mode, simply turn the command dial. In Program AE mode, press the shutter release button halfway and then turn the command dial to shift to different equivalent exposures.
Mar 21, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
My canon eos 400d will not autofocus in creative settings.
Hey mate,
I've been having the same problem. It annoyed me during a day out once.
Set the camera in one of the Creative Modes.
-> Then go to Menu (the button on the left of the screen)
-> Setup 2 (thats the furthest menu on the right)
-> Custom Functions (3rd option down)
-> Go to function 4 and change it to "0: AF/AE LOCK"
Hope that helps mate :)
Cheers
Baghdad_boy
Feb 18, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I can not get my canon eos rebel k2 focus on a
Autofocus is activated by pressing the shutter button halfway, be shure to have a EF lens in the camera, otherwise it won't make autofocus, put camera on full auto mode or "sports mode" (the running guy) and the focus settings on redictive AI Servo AF: Continuously tracks subject movement and achieves focus before the exposure starts.
Jul 10, 2009 | Canon Photography
Auto focus does not work in the creative zone
Sounds like your custom functions have been changed to work this way. On the EOS 350 D it is Custom Function #04. To change it back to default you need navigate through Canon's menus. Here's how to get there: while in one of the creative zones go to your camera menu and navigate to the 5th tab on the right. Select “Custom Functions (C. Fn)” from this tab. This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. That should get your camera back to the expected auto focus with the shutter button.
Happy shooting :-)
Feb 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Automatic aperture setting on canon FD lenses not working on AE-1
You have a case of AE(auto exposure) Unit faulty or getting bad. It suppose to register as it move within the AE unit according to the exposure calculation but somehow it is broken. Technician usualy replace the AE unit and takes care of the problem. It can also be rebuilt if new parts are not available. This requires complete disassembly and mirror box removal. The average cost of repair probably runs around $100. Yes, "A" mode is correct for most of the shots and it was a state of art electronic system and more computerized than you think. It has 3 IC chips in there for precessing and 1 chip for the exposure. All works together for good. -James
Nov 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
142 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
