Question about EliteGroup P6SET-ML Motherboard
D845GRG motherboard I have a D845GRG motherboard that I just purchased from Ebay. The board will do nothing wil not power up/no fans/no beepcodes. If I jump the green and black wires on pwr supply cpu fan spins and green led on mb, but no beep codes. The MB is not like the GRG manual. There is no AGP slot. and front panel header panel has 16 pins,10 & 14 empty. I think this was a pull from a Gateway Emachine. The seller say's it was from a working system. I assume it is a modified board for Gateway, so does that mean I need a Gateway case to bring up this board?
    President:
  • 415 Answers
Depending on your processor type and speed as well as ram, to save you a headache go to http://pricewatch.com and order a new motherboard with warranty, cd and manual.
Posted on Mar 09, 2009
What causes a pc motherboard cannot turn on ?
Do any lights come on at the case? eg at the front or on the port where the network cable is plugged in.
Does the psu fan spin when turned on?
If you can open the case, there is usually a green(?) led on the motherboard that lights up when powered on.
If nothing is happening, it could be your power supply. Try swapping it with a spare one (check that it is a standard pin layout.
Look at ebay, local pc store etc for a cheap atx psu tester to see it the power supply is ok. Or google how to jump start a pc power supply with a paperclip and/or test with a cheap multimeter - usually with the green and black wire from memory. (careful playing with electricity though and read up on how to not short out your computer and damage something else).
Otherwise, the motherboard itself may be dead.
Jul 25, 2014 | ASUS Computers & Internet
Emachine T2885 won't start up after I cleaned it with vacuum
unplug and remove the ram and battery remove the jumper on the clear mos for 5minutes Put everything back together make sure everything is seated firmly
Apr 12, 2009 | Intel Motherboard
Intel D845GRG Motherboard Display drivers for Window Vista
According to Inel this board does not support Vista. They have no drivers available. Sorry.
Mar 08, 2009 | Intel D845GRG Motherboard
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Fan and heatsink
Just ask for the fan & heatsink for the 478 socket. Its easily available in the market../
Nov 16, 2008 | Intel D845GRG Motherboard
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Intel D845GRG Motherboard Problem:usb wiring conection to board
Hi mrm291048,
The Intel D845GRG MB supports USB 2.0 & is backwards compatible to USB 1.0
For in-depth description of motherboard wire color & location click on this link & scroll down till you see, "Standard USB Cable Wiring Color Code". http://www.usbman.com/Guides/BelkinMotherboard_cable_assembly.htm
You'll also need to open your manual to page 68 If you need the manual for the D845GRG MB click on this link; ftp://download.intel.com/support/motherboards/desktop/D845GRG/BVRG_English.pdf
Between the two you should be able to set the correct colored wire up to its matching pin on the MB.
If this is not answering your question, please set me strait & rephrase the question.
Mike
Sep 30, 2008 | Intel D845GRG Motherboard
EliteGroup P6SET-ML Motherboard Logo
224 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
