Question about RCA P61929 TV
Color balance is off.
The screen appears to be bending at the top, and the tv is doing triples, kind of like when you have an antenna tv. I am told the color balance is off, but I'm not sure if that is all that is wrong, and the tv is too large to take to a shop.
  • 39 Answers
This my good sir, (or mam), is a convergence issue. very common rca failure. there is a convergence power module that has a 130volt regulator that goes bad. this can be fixed in-home by experienced technician for less tan 300.00 including parts, labor .& service call. the chip is an stk730-150. mch
Posted on Mar 09, 2009
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest...
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
Aug 01, 2008 | Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
With or without my indoor rabbit ears, cannot get any channels below 7. the people where i got the antenna told that i could connect my roof antenna to an adapter and connect it to the antenna input on the...
Hello
You heard is correct. Your roof antenna can be connected to your TV, after connecting it to a balancing coil adapter, usually called 'Balun Adapter" which converts the impedence from 300 to 75 Ohms. It can be bought for most of the electronic shops all around. Connect the antenna wire to it and then plug it to your TV antenna in socket. The stations will be very clear, and well defined. You may have to turn the roof top antenna towards the direction of the transmitting tower to get a well defined, ghost free image. OK.
Mar 27, 2011 | Televison & Video
Sony dvp-ns425 player has the word VIDEO in upper right corner appear and disappear every 20 seconds or so. It is in the same green block letters as all the menu/control titles so I know it is from the dvd...
That word Video in green color could be TV's on-screen display as DVP-NS425 has another kind of on-screen display that has track info, time info etc in display.
Please press Display on TV remote to turn off that green color Video on-screen display at top right corner.
Thanks.
Sep 13, 2009 | Sony DVP-NS425P DVD Player
I've just hooked up my converter box. I can get most channels with decent reception. However, I can't get my NBC affiliate. I've been told that I need a new indoor directional antenna. What kind shoul
Totally depends on how far you live from the station you want. I sell antennas, converter boxes, the whole shebang at my retail store, and you're not alone in your confusion :-) My best advice to you is this:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
May 22, 2009 | Toshiba 13A25 13" TV
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Color balance of video output
an estimate of repair is pointless it would cost less just to get a new camera.
Jun 26, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
SEEING TRIPLE
Possible problems: 1. Ghosting is caused by an ingress of off-air signals into the TV through the cable system, or the TV's antenna 2. An F-connector may be loose 3. The cable plant may have a "leak" in the area Solutions: 1. Check and hand tighten the cable fittings to the TV set and VCR. 2. Remove the antenna from the VHF terminals when cable is used. 3. A converter or A/B switch may be needed to correct the problem (A/B switch enables you to bypass the set-top cable box or descrambling cable box and tune all unscrambled channels directly with your TV, antenna, or VCR). good luck!
Jan 02, 2006 | RCA P52929 52" Rear Projection Television
Televison & Video Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
