Question about LG DR787T DVD Recorder
LG LCD TV remote power button turns off LG DVD Recorder as well
I have an LG LCD TV and an LG DVD Recorder. If I am recording a show and decide to turn off the TV but leave the show recording, pressing power on the TV remote (or the console) turns off the power to the DVD recorder as well and then all that gets recorded is a black screen. The problem also seems to happen if I am timer recording a show, if the TV is not on then all that gets recorded is a black screen.
Does anyone know how I can stop this?
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Posted on Mar 18, 2009
LG smart TV turning on and OFF?
Anyone using a remote for something else nearby? (My DVD player/recorder remote turns my VCR/DVD recorder on and off). Or, is anyone playing a joke on you with a universal ''turn off/channel changer'' remote? (They are intended for harassment).
How old is the TV? Is it LCD, LED or Plasma? If plasma, this could be the beginning of display failure. If LCD or LED, it could be a bad power circuit board. Most ''techies'' are quick to say (and they are correct) ''replace the caps'' without thinking about the fact that most circuitry is ''surface mount'' design these days, and the average DIYer can't ''DIY'' a surface mount repair.
Jan 02, 2015 | LG Televison & Video
How do i connect my jvc camcorder to my lg recorder
These instructions should be very similar to hooking up to your lg recorder Hope this helps
Instructions
    • 1 Plug the white and red audio cables into the left and right Audio OUT ports on the back panel of the DVD player. The ports should be color-coded white and red as well, but if not, connecticon1.png the white plug to the left audio and the red to the right.
    • 2 Connect the yellow plug to the Videoicon1.png OUT port on the DVD player.
    • 3
    • Plug the other ends of the three cables into the matching composite AV IN jacks on the back of the JVC LCD TVicon1.png.
    • 4 Turn on the DVD player and the JVC set, then press and release the "Input" button repeatedly on the TV remote control until the DVD screen appears on the LCD panel.
Read more: http://www.ehow.com/how_6647268_hook-player-jvc-lcd-tv.html#ixzz303ZGkASL
Apr 26, 2014 | Computers & Internet
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
How can I play a Region 1 Dvd in Australia?
power on the tv and dvd without any dvd in tray
open disc tray
press pause then 0000000 on remote
region menu shows on tv screen
select ur region
press pause on remote
then power off
Jan 26, 2010 | LG RH177 DVD Recorder/HDD Recorder
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
Dec 29, 2008 | LG RC897T DVD Recorder/VCR Combo
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
LG DR787T DVD Recorder Logo
613 people viewed this question
Computer Repairing
Computer Repairing
