Question about LG DLE8377 Dryer
Dryer puts out heat, but clothes are still wet
Checked heating elemant, coming on. Checked 240 power, checked the venting, still having problem. Clothes run through whole sycle, they are warm to touch, but are still completly wet.
  • jessicajo932 Mar 09, 2009
    We already checked that also, fully cleaned out trap and exhaust. Also tryed it on every setting I have and all the temperatures available for each.
  • LG Master
  • 8,220 Answers
  • 221 Answers
There may be a clog underneath the lint trap or the exhaust vent may be clogged, if either fails try changing temperature knob to a different setting.
Posted on Mar 09, 2009
The dryer is not get hot. It take 2or 3 times ti dry the clothes
You might want to take a flashlight and check the vent and duct from the outside in. Lint will build up in the duct and vent over time. When you turn on the dryer with wet clothes in it, the lint will get damp quickly and it will dry out quickly too which make the dryer cycle shorter but not long enough to dry the clothes. Clean the vent and duct regularly and that should take care of your problem. You can buy brushes for doing this and they are not costly.
Jan 04, 2015 | Frigidaire Dryers
The heat is there but it doesnt dry the clothes
You have one of 2 problems. Your clothes are getting put into the machine too wet because the washer isn't spinning them out all the way. Or you have a clogged vent causing the unit to take too long to dry properly because it can't remove the moisture properly. Check your vent outside to see how hard the dryer is blowing the air.
Nov 27, 2013 | Zanussi TC7114W Electric Dryer
Takes to long to dry clothes
after checking and replacing the vent going outside still the air was not venting and inside my drier everything was wet although the air was hot. After removing the rear panel i saw the blower belt disconnected. it took me some time to get the belt on but everything is ok and the air is venting and clothes getting dried. Also note that the little pulley came off its positio too.
Feb 14, 2013 | Whirlpool Dryers
I have a 7 cycle ele dryer (roper) my dryer is heating up but won't dry my clothes and.very little heat coming out from vent I had a new heating element put on what can be wrong with my dryer please...
When your dryer heats yet does not dry the clothes its usually always a poor air flow problem. What needs to checked is for lint build up in the blower housing,a chushed and or restricted vent from the rear of the dryer or anywhere to where it exits the house.
GENE
Sep 09, 2011 | Dryers
My dryer we've had for about two months won't dry clothes. it heats up, but they are still wet four cycles later
I was thinking you have a bad circuit breaker. This dryer runs on a 2 pole 30 amp 240 volt breaker. The motor runs on one side of the breaker on 120vac. The heater has to have 240 volts to work correct. When that breaker is on the way out it will take a new dryer 3 or four times as long to dry the clothes. themobilian_294.jpg
If you are cleaning the lint filter out and don't have a clogged vent pipe themobilian_295.jpgthen in my opinion you have a bad circuit breaker. Seen it.
Nov 27, 2010 | Amana NDE2335AY Electric Dryer
Dryer will not dry clothes after 60 minutes in the dryer clothes still wet just like they had just come out of the washer.
The reason you are not getting the cloths dry after 60 minutes and are just as wet is airflow or rather the lack thereof.
First verify that you dryer is actually starting, (I know... you're thinking, duh!) but simple things first. Let the dryer run on high heat for about 2 minutes and open the door. See if there's actually heat coming out of the door. If there is, that's a good sign. Did the drum seem to be tumbling? if yes, this also is a good sign.
Next turn the dryer to fluff/no heat and turn it on. Go outside and check the dryer vent (if possible) and see if there is a reasonable amount of airflow coming out. Most likely it will be weak (since your cloths aren't drying.) Now that you have checked that, go inside, disconnect the dryer hose on the back of the dryer. Compare the airflow from the outside vent. If it is considerably stronger than outside, your ducting needs cleaned. If it is about the same and still weak, something is blocking airflow in your dryer.
Here's a decision point. If you feel you don't want to try to fix the dryer yourself, get someone qualified or take it to a qualified maintenance shot for the dryer. If you feel up to the task, FIRST unplug the dryer, then you'll have to disassemble the dryer (can't give you specifics without the model number) and find the clog and remove it. Once the clog is removed (very likely lots of lint and maybe even a sock or two) reassemble the dryer, hook the vent hose back up, plug it in, try to dry your cloths.
Hope that helps
Nov 14, 2009 | Whirlpool Dryers
I have a roper dryer Model RES7646KQ2. While I
Sounds like thermal cut off fuse has blown. That is indicative of airflow obstruction somewhere either internally in the dryer or venting from dryer to outside v
Nov 15, 2017 | Roper REX4634KQ Electric Dryer
My tumble dryer still spins but there is no hot air coming through, the clothes are coming out as wet as they went in.
A dryer operates on 208 to 240 VAC. Make sure the voltag at the dryer is correct. Check circuit breakers (flip off, then back on) or fuses. Missing one leg of power to the dryer will allow the motor to run on it's 120VAC circuit, but not have the needed 208 to 240 VAC for the heating circuit. Beyond that, no heat can be caused by a failed heater, one of two thermostats, fusable link(s), motor switch, timer or electronic control, sensor or a wiring harness problem. After you verify correct power at dryer recepticle, and still have no heat, I suggest letting a pro help you on this one.
Nov 04, 2009 | Televison & Video
No heat in or coming out of the dryer Whirlpool LE6800XTWO
FIRST CHECK YOUR THERMAL FUSE FOR CONTINUITY IF NONE REPLACE IT AND REPOST
Apr 17, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
256 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
