Question about ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Tv has great sound, no picture. it just flashes with color burst
This is a pdp4294lv1. all inputs supposedly work for video, but just continuously flashes intensively sometimes.
This site needs to get back to people and help with this problem mine is doing this also
Posted on Apr 30, 2009
Blinking color on screen no picture
Sounds like a panel fault. Contact the authorized service center for Philips to confirm.
Gopakumar Gopalan Google
Apr 17, 2014 | Philips 42TA648BX 42 in. LCD TV
Plasma tv burst colors
The problem sounds related with its energy recovery circuit. Check this link for more details about these kind of fault.
Feb 05, 2013 | Samsung LN-S4692D 46 in. LCD HDTV
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
No color.
Hello strata_rocks,
This denotes a possible malfunction of the chroma (color) circuits in your TV. You will need to check and see if your chroma signal is being generated at the output of the video processor IC. In addition you want to check the video signal to make sure that the color burst signal is present once the video signal is modulated from the IF input section of the video processor.
These are start off points for your troubleshooting. If you do not have a background in electronics, you have two options, the first is to replace the video board, the second option is to have a qualified TV repair person work on your television and change the board out, after troubleshooting the problem.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
No Sound
sounds like you are using componant cables.[ red,blue,green on the right side in back of the cable box for the picture, & red & white cables for the sound.] make sure the red & white cables are connected to the middle white & red outputs of the cable box to the tv's red & white inputs, not outputs. hope this helps.
wg
Feb 06, 2008 | RCA D52W15 TV
No Picture on TV
? What is the model # off the back ?
Does the video work on the RF coax cable input?
For instance,as a test,can you hook-up from VCR coax RF out
to TV coax in,put the TV on Chan. 3,play a tape and get audio and video?
Are you matching colors when trying the A/V inputs?Yellow,red,
and white out of DVD to yellow,red and white in on back of TV?
Then select video input on tv===dial "00" or use input button on
original RCA remote. Are you using original RCA remote that
came w/TV ? Do you have the owner/operator manual for the TV?
   Sorry to ask so many  ?????   Let me know how it goes!!  T.
Oct 17, 2007 | Televison & Video
Metz CRT TV G3478 color problem in PAL mode
I see from your profile that you have not specified your location which make it tricky to be sure which standard you should be using.
Oct 07, 2007 | Televison & Video
White Noise Sound
Your problem is somewhere between the tuner and video detector circuit. The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess! After the audio passes through all this, it is detected and sent to the audio processor. If any frequency has drifted away from it's value then you loose the sound. SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem. Stargazer
Mar 11, 2007 | Proscan PS32600 32" TV
ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV Logo
173 people viewed this question
Top ESA Televison & Video Experts
Demonic-2011
Demonic-2011
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
