Question about Hoover Hardware & Accessories
Loud knocking noise
The vacuum caught on a shaggy rug, I turned it off and it smelled like smoke. Removed the brush cover and did not see any thing caught in the brushes. It now makes a very loud thumping, knocking noise. Not sure if it could be the belt - because this happened in less than five minutes of its very first use!
    Top Expert:
  • Hoover Master
  • 45,932 Answers
It doesn't take long to destroy a belt.
Posted on Jan 04, 2018
5 Suggested Answers
  • 58 Answers
SOURCE: brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
Posted on May 29, 2009
Vac Belts
  • 701 Answers
SOURCE: Makes a loud noise like a grinding noise.
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Posted on Nov 30, 2009
  • 262 Answers
SOURCE: Roomba 530 makes a thumping noise every secondand ...
You also need to pull off the yellow bearings from the end of the brushes (one on the brush one and one on the rubber one) and remove hair from the axle there.
Posted on Jan 19, 2011
SOURCE: The floor brush will not
I recently had a similar problem where the vacuum would turn on but the brush would not rotate. I could hear the motor turn on and the belt was in tact, but the brushes would not turn. I took out the brushroll and it would not turn by hand either. There is a white cap on one end of the roll and a black one on the other. Use a hammer and a punch (or sturdy screwdriver) on the metal rod from the white end to knock the metal rod out of the roll. There is a bearing and wave washer on each end. I cleaned all of the hair and gunk out of both bearings and it rotated much better. I actually bought a couple of new bearings (trade # 608 - same size as what's in rollerblades) and lightly sanded the surfaces where the roll and caps meet so I hopefully won't have to do this again for a while. I heard of people putting WD-40 on the rims of the caps, but I wouldn't recommend this because I don't think the plastic would react well to it. Hope this helps.
Posted on Nov 21, 2012
Bissel vacuum cleaner
Some thing like rug or too much hair vine the brush to prevent the brush to spin when the motor is on. So it just keep pulling the belt that's why there is smoke.
-Check it , clean it and possibly need to replace new belt.
Good luck/Keep clean
Mai Lor
Oct 11, 2017 | Bissell Vacuums
While using the power mate rug part I caught a small rug and the vacuum would no longer pick-up .
Check to see if there is a reset button on the head. This protects the machine for times like you described. When something jms up the reset button will turn ofdf th machine. Simply push the reset. Hope this helps, Chris
Feb 07, 2011 | Kenmore Vacuums
Burning smell loud grinding noise when tilted
Hi there SmartAlec from NelsonVacuums.com.au here. The rattle is the clutch engaging. It can happen for a couple of reasons. The best case for you is if there is something caught in the brush roller that you can simply remove. The next best is that the end caps of the brush are full of junk that you will be able to remove. Its not easy getting the brush out to clean there but it can be done.
If the brush spins in your hand easily when the brush is removed then it is the clutch itself. THe main roller often melts which is caused when the tension on the belt gets to high thus creating too much heat. THis can be resolved only with a new clutch.
Hope this helps, if you have more questions dont hesitate to reply or if you need parts just visit
NelsonVacuums.com.au.
Happy Vacuuming :)
Apr 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loud rattling noise.
Hi there SmartAlec from NelsonVacuums.com.au here. Often when an upright is making a rattling noise it can be something caught in the roller and every time the brush turns it knocks against the body and since it turns really fast it can sound quite bad. Take the roller out and clean inside that area and see if that helps. Hope it does. Happy Vacuuming :)
Aug 03, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
My dyson D17 is making an incredibly loud noise, like grinding, when the bottom brush rotates.
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
Aug 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Loud noise, smell smoke, brushes turn slower than before, stoped using
yes there are replacement parts for your hoover call any athourized hoover dealer and give them your model # usualy the motors are more expensive than the hole machine
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Wind tunnel supreme sounds very loud
Sounds like a bad motor, you have a years warranty on this, take it in for warranty repair. You will void the warranty if you mess with it.
May 08, 2008 | Vacuums
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Hardware & Accessories Logo
52 people viewed this question
Top Hoover Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hoover Hardware and Accessory Expert? Answer questions, earn points and help others
