Question about Kodak Digital Picture Frame
How do I get music into SV1011 digital Picture frame
I want to put music into my digital picture frame, how doe this get done?
    Genius:
  • Kodak Master
  • 1,099 Answers
There is no internal memory on your frame. Therefor you must transferre the music onto the SD card and then it will play from your frame.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 16, 2009
I have misplaced the user manual for my SV1011 Kodak Easyshare digital picture frame. How can I download music to play, along with my photos?
You can view/download the manual at
http://support.en.kodak.com/app/answers/detail/a_id/18780/kw/sv1011/selected/true
The relevant instructions are in "Playing music" under "Doing more with your frame".
Jul 10, 2011 | Cameras
Tip
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
KODAK SV1011 ALL PICS HAVE A RED HUE??? ANYTHING
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these troubleshooting steps:
1. Turn the frame off.
2. Unplug the power cable from the wall outlet.
3. Remove any memory card or flash disk from the frame.
4. Connect the power cable directly to a wall outlet.
5. Turn the frame on.
6. Use a paper clip to press the button inside the pinhole on the back of the frame.
If after trying the above steps and the frame still have the same problem, then we need
to send the frame in for a repair as per warranty guidelines.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
Dec 15, 2009 | Kodak EasyShare EX1011 Digital Picture...
I have a kodak sv1011 digital frame and it stopped showing the pics. it boots up and you can see the pics if you look closely but there is no back light so it won't display? is there a fix for this?
On the other side of your frame there is a reset button.
It is below a small hole on the left back side of the frame. You will need a poky device in order to press the button which is located within the frame.
Contact KODAK:
Jun 19, 2009 | Kodak Digital Picture Frame
Can't transfer music (audio) to the Frame
Make sure the music is in the correct file format for the frame. Some frames take MP3, others take WMA. If the format that you have is not compatible, you must convert it or the frame will not read it.
Jan 29, 2009 | SmartParts SPX8 Digital Picture Frame
Customer service to help me to use quantaray by sunpak
I have a quantaray 15" photo frame and I cannot get the screen bright enuf to see the image.
Dec 31, 2008 | Quantaray 7-Inch Digital Picture Frame -...
HOW TO PUT MUSIC ON FRAME
I just received a gpx photo frame. I can not copy from my memory card to photo frame. Has built in 1 gig memory
Dec 24, 2008 | Nextar N7 - 7 Digital Photo Frame with...
Kodak   Digital Picture Frame Logo
235 people viewed this question
Top Kodak Photography Experts
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
