Question about Kolcraft Universal 46250L-N
List of compatible car seat for Kolcraft Universal..
List of compatible car seats for model # 46250L-N Universal Car Seat Carrier by Kolcraft.
DO GRACO SNUGRIDE INFANT CAR SEAT BASES WORK WITH A DIFFERENT MODEL?
Some do, some don't.
From Graco's web site:
What base will work with my car seat?
We have designed many of our car seats to work with more than one base, for your convenience. Please see the chart here for Classic Connect models.
The SnugRide Click Connect 30, 35, 35LX and 40 infant car seat carriers are compatible with any SnugRide Click Connect infant car seat base. Consumers should adhere to the height and weight requirements for the SnugRide Click Connect infant car seat carriers as stated in their owner's manual; however, the SnugRide Click Connect 40 infant car seat carrier is restricted to a height limit of 32 inches when used with a SnugRide Click Connect 30, 35 or 35LX base.
Jun 15, 2014 | Graco Baby Gear
Need a base for eddie bauer infant car seat model IC-048
I would recommend contacting Eddie Bauer directly to find out what base works with their Infant car seat, model IC-048:
BY PHONE
24 hours a day 7 days a week
1-800-426-8020
BY MAIL
Eddie Bauer Customer Service
P.O. Box 7001
Groveport, OH 43125
For Hearing Impaired Service:
TTY 1-800-462-6757
M-F 7-3:30 EST
To e-mail Eddie Bauer: http://www.eddiebauer.com/custserv/ask_eddie_email.jsp?sectionId=24448
Jan 23, 2013 | Eddie Bauer Baby Gear
Can a Maxi-Cosi Mico infant car seat fit on a Quinny Buzz 2006 frame?
Hello - We don't have the Maxi Cosi Mico in the UK, so we're unable to respond to questions relating to this model carseat. Please contact Dorel USA for clarification on this - crelations@djgusa.com
Nov 27, 2011 | Maxi-Cosi Mico Infant Car Seat
I bought the Peg Perego Venesia Stroller and Primo Viaggio infant car seat used. I do not know how to run the straps through the infant carrier or how to completely attach the carrier to the car seat...
hi I'm sure this is just the newer model the uno looks the same as the venezia
http://global.pegperego.com/babyproducts-catalog/2010/Uno
instructions available at this website
Nov 17, 2010 | Peg Perego Primo Viaggio Verde Infant Car...
I need the installation manual for Graco Infant car seat/carrier model no. 1760973, Pooh "Snug Ride"... anybody?
http://www.gracobaby.com/CustomerService/ProductInstructions/Pages/default.aspx?page=ProdInst
Jun 09, 2010 | Graco SafeSeat Infant Car Seat - Soho
I need to put the straps back in seat
When I was doing research on your problem, I came across this recall. Please read and see if it relates to your product. RECALL ID# 66785 - CHILD SEAT Recall Date: July 28, 1993 Model Affected: AUTOMATE Recall Summary: THE TONGUE OF THE BUCKLE ASSEMBLY CAN CORRODE. THIS DOES NOT COMPLY WITH FMVSS 213, "CHILD RESTRAINT SYSTEMS." ALSO, THE LABEL WITH USE AND SAFETY INSTRUCTIONS IS MISSING FROM THE PLAYSKOOL MODEL. Consequences: BUCKLE ASSEMBLY CORROSION COULD AFFECT THE SAFETYPERFORMANCE OF THE CHILD RESTRAINT. THE MISSING LABEL MAY CAUSE IMPROPER USEOF THE CHILD SAFETY SEAT. Remedy: KOLCRAFT WILL PROVIDE OWNERS WITH A FREE REPLACEMENT HARNESS ASSEMBLY AND INSTALLATION INSTRUCTIONS. OWNERS OF THE AFFECTED CHILD SEATS SHOULD CALL KOLCRAFT TOLL-FREE AT 1-800-453-7673, TO OBTAIN A NEW REPLACEMENT HARNESS ASSEMBLY. Notes: KOLCRAFT ENTERPRISES, INC. Potential Car Seats Affected: 307017
Dec 29, 2008 | Kolcraft Universal 46250L-N
Missing Instruction Manual
try the manufacture website at this link
http://www.coscojuvenile.com/instructions/
you will need manufacture date and model number and you can view them online
Aug 04, 2008 | Baby Gear
Need to Re-Assemble my Graco Snug Ride Car Seat
Hi jessibee
I found the site that you need to get an instruction manual for the seat. You will need to find the exact model of the SnugSeat that you have, because there are quite a few to choose from.
to find the model/serial number...
Car Seat trans.gif Toddler or Booster - On the back of the car seat OR on the bottom of the seat
Infant - On the back of carrier OR on the bottom of carrier OR on the stay-in-car base
Thanks for using FixYa, a Fixya rating would be great for this advice.
Good luck.
regards
robotek
May 09, 2008 | Baby Gear
Eddie bauer
Rather than just trying to give you general advice without seeing the car seat, where I live the local fire department will check your car seat for compliance to safety codes and if you bring it to the firestation I believe they'll basically help set it up properly. It might be worth checking in your area.
General guidelines are that an infant has to be rear facing, backseat only. Modern seats and cars come with a belt with universal clips at each end. This belt passes through the car seat and clips into the universal connectors which are hidden either between the seat and the backrest in the car or are accessible through slits in the backrest. The belt should be secured tightly enough so that it doesn't move a lot while a little side-to-side movement is ok.
If you don't have the universal connector belt the seat can also be secured with the cars seatbelts. Check the manual for your car for diagrams showing how this can be done.
The seat should also be tilted back (towards the front of the car). Some seats have level indicators built in which tell you if the seat is tilted within the proper range.
There have been some recalls of Eddie Bauer car seats and the list of model numbers might be worth checking (if you are able to determine your model number without the manual).
http://www.automotive.com/car-seat-recalls/136/eddie-bauer/index.html
Jan 07, 2008 | Baby Gear
Kolcraft Universal 46250L-N Logo
81 people viewed this question
Top Kolcraft Baby Gear Experts
Jennifer Rock
Jennifer Rock
Iron
Iron
Are you a Kolcraft Baby Gear Expert? Answer questions, earn points and help others
