Question about Motorola Mobility KRZR K1m Cellular Phone
I cannot change the time on my motorola KRZR phone. under the settings option, it has everything except date and time..under settings there is : ring stly,es personalize, in call setup, security, initial setup (also no time/date function under this menu),network info, car settings, headset,location, connection,apps setting.. does anyone know how to change the time? please help me!
  • 1 more comment
  • Anonymous Mar 10, 2009
    i have the same problem i cant get the time change on my phone... pls help!
  • Anonymous Mar 24, 2009
    me too!!!!!!!
  • Anonymous May 14, 2009
    same problem
Did you restart your phone?
Posted on Mar 09, 2009
My motorola c350 language has been changed. Now I cant read the language for what its getting difficult to change it to English. Please help
Download the user-manual from this site. http://www.motorola.com/mdirect/manuals/C350_gsm_User_Manual_E.pdf
Observe the menu map. From your main menu, you have to open more (It has box open icon). Under More, you have to open Settings(Two mechanical bolts icon).
Under settings, you have to go to Other Settings which is the 5th option.
Call Forward
Phone Status
In-Call Setup
Security
Other Settings *
Under Other settings, you have the following options:
Personalize
Initial Setup
Network
Car Settings
Headset
You have to select the 2nd setting, that is Initial Setup.
Under Initial Setup, you have the following options:
Time and Date
1-Touch Dial
Backlight
Zoom
TTY Setup
Scroll
Animation
Language
Battery Save
Contrast
DTMF
Master Reset
Master Clear
You have to select the 8the option, which is language(langua/idioma/langue).
Now from the options select English to set english as the changed language.
Jul 20, 2011 | Motorola Mobility C350 Cellular Phone
My krzr wont ring on incoming calls any more and i have tried everything i can find in the menus to get it to work.
If you try to change ringtones, do you hear the new ring tones? If not it could be your ringer speaker has gone bad.
Sep 30, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
With my Motorola l6 i phone i can't open initial setup in the settings to change the time and date so now i have the wrong time and the wrong date on my phone and i can't even change it. What should i do?
hi,
i would try to help you out in this regard, but before this let me know whether you have set any password to other options in the settings like.. personalize, or ring style or connection or call divert.
if you have the password to any of these, first try to remove the passwords to those options and restart your mobile, this should be fixed, you may ask that what is the relation b/w this option and other options, this could be because of some bugs in software building..
if the issue persists, write back on this with the exact error message you see.. or any thing that happens when you try to open it...
Narendra Tirunahari
Jul 10, 2010 | Motorola Mobility L6 Cellular Phone
Changing the time on my Motorola Razr V3 phone
you must first disable Autoupdate (turn it off) - go to settings>scroll to Initial Setup, (select this)>Time & Date (select this)>Autoupdate (set to OFF)>after you do this option will appear to change time to 12/24 hour....
May 11, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Krzr won't stay on t9 text
open a new text message go to "options" select "Text Setup" and change the primary text: to iTap English instead of TAP English this will fix ir :]
Mar 07, 2009 | Motorola Mobility KRZR K1m Cellular Phone
K1 KRZR by motorola - network unlock / subsity code
I also have a KRZR. From all the research I have done there is no way to unlock it with the IMEI no. I have tried several times. Went to our local flee market and found someone that unlocks cell phones. He tried everything except a test point. He would of had to cut into the phone and then couldn't guarentee that would work.
Aug 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Jul 28, 2008 | Motorola Mobility RAZR V3
Ringtones on my moto krzr
did the tones come pre installed on the phone? why dont you try using mp3 ring tones? download mp3 songs on your phone, then you can set them as ring tones. they work much beter than ordinary ring tones
Jun 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
My time doesnt change at daylight savings time
Go to settings,initial setup,time and date. change it to "off" on autoupdate.You'll get more options. You can change the date and time then.
Nov 04, 2007 | Motorola Mobility RAZR V3
Motorola Razr V3, no autoupdate for date and time?
The only way you're going to fix this is if you update your firmware. Check http://www.modmymoto.com/forums for some help on that.
Feb 20, 2007 | Motorola Mobility RAZR V3
Motorola Mobility KRZR K1m Cellular Phone Logo
834 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
