Shuts down while at an idle or going down the road. I just replaced the cam position sensor. It starts back up right away and runs for a little while and then shuts down again. The engine light is on because #6 glow plug is bad and showing a code for it. Does it keep shutting down because of the bad glow plug? It is showing a code for the bad glow plug, but is it supposed to shut down for that?
I have had the same problem with my Ford mustang the only thing is that it only shuts down in high idle, after the engine temperature warms up there is no shut down. It could have something to do with the transmission or the temperature sensor the best thing to do is get a full diagnostic and not do it your self.
SOURCE: 2001 jeep grand cherokee 4.0 engine shuts off
it is possable/likely a bad ECTS (engine coolant tep. sensor), this can cause the injectors to allow to much fuel into cylinders and cause a low compression and or flooding situation, good luck, marty
SOURCE: 91 f150 4.9L no visible timing marks, hard start runs rough.
I have wondered why this happens many times in the past. You would think the marks should line up using #1 cylinder but they don't.
It has been a while but I think if you hook up to #5 ignition wire the marks will come up for you.You will need to undo the "spout" connector before setting it to 10 degrees before top dead center. The spout is a two wire jumper clip that should break out of the harness at the distributor.
Warm the engine up for a while so it doesn't stall as easy while you set the timing.
Testimonial: " Right on, timing it on #5 cylinder worked. I thought I probably had a bad damper but it appears o.k. "
