Question about Jenn-Air JCD2295HES Side by Side Refrigerator
Doors do not line up - Jenn-Air JCD2295HES Side by Side Refrigerator
SAFELY REMOVING DOORS FOR SHIPPING
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
Need to remove doors from a Shelvador side-by-side fridge to get into house.. How to disconnect water line to door?
Most of the water lines have a quick connect fitting down at the bottom under the unit. Open doors, remove kick plate and follow line back. Should have a connection in that area.
Aug 18, 2012 | Refrigerators
Re ajust vw beettle 64 doors
You just fool with the adjustments until they line up properly, a very time consuming job on this car. Bring your lunch.
Apr 26, 2012 | Cars & Trucks
On-line parts diagram AC/Heater
Blend doors are in the heater and A/C box, typically not a job for non professional, very very delicate
Sep 01, 2009 | 2001 Buick LeSabre
Water dispenser doesn't work on ge hotpoint freezer
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
Apr 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
1989 ford mustang lx rear hatch and door alignment problems
Use a t-47 torx bit and adjust the latching pin in or out to line up the hatch, simple as that!!!
Mar 27, 2009 | 1989 Ford Mustang
Hvac doors not working
Its probably the vaccum line. Check again. There is a small thin one that crosses over the top of the engine and fails/leakes/cracks in the area where it is hard to see. Repalcing the vaccum lines for $10 is the place to start. Then see what happens. While the engine cover is off, go ahead and change the PCV valve and give the engine a quick check for any other loose connections or issues.
Nov 13, 2008 | 1999 Chevrolet Astro
'99 Astro blower doors not moving to allow air flow.
I had the same problem...
There is a vacuum line that operates your selector switch, it is located under the hood, roughly in the center, up against the fire wall. If the line has leaks, your selector switch will not work and therefore all your blower doors will stay shut. Replace the line.
Nov 01, 2008 | 1999 Chevrolet Astro
Sub zreo side by side
open the doors ajust the hinges so the doors line up
Oct 28, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
90 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
