Question about Coleman Powermate Powermate 5000W Generator
I have a cloeman powermate 6250. It has about 20-25 hr. on it,our power went out today so I hooked the gen up. It worked good for about 10 min then no power, motor running fine. Once a month I would start it, run under load for about 5 mim,what could have went bad. Bud Smith dr5803@sbcglobal.net
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
Ther is a reset button for the poweer output. I know i you probably checked, but if not try this.
Posted on Jun 03, 2009
Can voltage on Powermate be adjusted?
yes
the adjustment is by the rpm setting on the governor spring
thee is a nut that you adjust the spring tension with and lower the rpms and watch the voltage gauge until you get the desired voltage
if the load is going to be constant but is well within the rated capacity( example 2kva of a 6.5 kva set) of the gen set then the variation when the load comes on will be less than 5 volts
however if the power required is close to the max capacity of the gen set ( example 4.5kva of a rated 5 kva set) , then turn the unit on and adjust the rpms up to the required voltage required
remember that an advertised kva is not the rated kva
rated kva is what the gen set will produce all day and is normally around 1kva less than advertised kva
so if you have a 6.5 kva gen set ,it will handle current peaks to 6.5 kva but will burn out if required to run long time at that load
if the gen set is 1000 watts then rated watts will be less ( 750-800) for long time use
Oct 22, 2015 | Electrical Supplies
Powermate 4000 watt gen set shuts down after 10 mins of operation
Coils do develop thermal issues sometimes - replacing it is a good place to start.
Sep 13, 2017 | Coleman Powermate 4000 Watt Generator...
We just bought a coleman powermate 5,000-6250 gen and it runs great but will not produce electricity. i hooked a 75 watt bulb up to each plug in and it would just barely come on the fade out. but would...
Your generator produces proper voltage and 60 cycles at 3600 rpm. Use meter to adjust voltage/engine rpm. If after adjusting rpm setting and gen. does not have proper power, remove cover to generator and examine brushes and commutator rings for wear and voltage regulator/rectifier for burned components swolen or leaking capacitor and replace parts as necessary. Parts are available www.jackssmallengine.com Good luck
Sep 09, 2010 | Coleman Powermate Powermate 5000W...
The cloeman 1850 portable powermate generator
Check spark, is plug wet? use sae 30 oil for summer use
Apr 11, 2010 | Coleman Powermate Premium Plus 6250W...
Where can i buy carburator for a 5500 watts cole powermate gas genarator it is going overseas.
coleman parts are all available from coleman on line, go to their site and click on the "parts" link
Dec 28, 2009 | Coleman Powermate Powermate 5000W...
No connection for a 5000 Watt Devilbiss gas generator.
i'm specialized in generators...but your problem seems familure...
try getting an L14-20 female connector ...i wish i had more details but this is all i can advice.
Sep 30, 2009 | Coleman Powermate Powermate 5000W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman generator 4000
powermate went out of business , but here is a website http://www.powermate.com/contact.php
you can probably get a off/ on switch at your local small engine repair shop. it probably can be any switch for a gen.
Sep 18, 2008 | Coleman Powermate Premium Plus 6250W...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Coleman Powermate Powermate 5000W Generator Logo
251 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
