Question about Proscan PS36109 36" TV
Sounds like it wants to turn on but shuts off
Whe I turn it on I hear some clicks, the sound it normaly makes when you turn it on, as if it is going to start but shuts itself off after 3 or 4 attemps Please help!
  • 111 Answers
Sorry but the clicks is the protect circuit saying you got a big problem. Usually, there is a short condition inside. If you have a multimeter you can start around the HV circuit checking for shorted caps or diodes or Transistors, otherwise it's a shop repair...Safety first....residual voltage remains even with power off, so be careful..
Posted on Mar 09, 2009
2003 dodge caravan will not start. Makes a clicking noise, and dash shuts off, then makes a humming sound.
im going to say an almost dead battery .the hum you hear might be the fuel pump.you never heard it before because the van normaly starts .so boost your van if it starts you may have to replace the altenator the guages, no worries many cars do that .thats a code needing erased and if you disconnect the battery that may go away.
Nov 22, 2013 | Dodge Caravan Cars & Trucks
I dont hear the buzz from my fuel pump last night my gas light came on. shut the car off for about 20 min and now will not start. put gas in it ,felt like it was going to start but never did. normaly i...
If you hear any noises from a fuel pump that's probably not a good sign, but I'd suggest checking your starter if the car wont turn over. If you think fuel is the problem check for any leaks that are visible, it could be a vacuum leak but I doubt that because that wouldn't prevent the car from starting.
Feb 28, 2012 | 2007 Suzuki Grand Vitara 4WD
If it has a fuel pump relay check that first. if the relay is good your fuel pump is probably on the fritz.(bad).
Nov 24, 2017 | 2007 Suzuki Grand Vitara 4WD
When i try to turn my tv on i hear 3 clicks then nothing else no lights no picture no sound it wont turn on
It's trying to go back home to Kansas...jk. It's in a "Shut-down" mode to protect itself from a possible short circuit in the power supply. Need to take it to a shop - could cause a fire.
Nov 15, 2010 | Toshiba 32WLT58 32 in. LCD Television
Playstation 3 (PS3) Console: Whe i touch the red startup button it beeps and tu...
you got a YLOD yellow light of death when you get a yellow light briefly and then the red lights start blinking, you need to reflux the solder on the processors and apply heat to them, here is a link on how to do the repair, if you are not good at doing these kind of work, I would suggest taking it to a pro.
http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related
May 17, 2010 | Sony Playstation 3 (PS3) Console
TV KEEPS SHUTTING ITSELF OFF
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is BP9600224B you can find it here: http://www.discount-merchant.com/Samsung-BP96-00224B-OEM-Replacement-LAMP-BULB-BP-p/samsung-bp96-00224b-oem.htm?Click=48173 .Have a blessed one!
Apr 29, 2010 | Samsung HLN5065W 50" Rear Projection...
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
This is a panasonic saht70 home theater whe turned on makes a clicking sound and does not go on shuts off immediatly sometime a loud sound from one of the speaker
Power supply may be burned out. These can be replaced but your local Panasonic service center will identify and correct any other lingering problems. (cooling, shorts, and general cleaning) Try thier support center website under the web address once you get on the main panasonic site.
Apr 28, 2009 | Panasonic Home Theater System System
Magnavox 27m53404/17 Picture went out
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
60HZ
120V
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Anthony
Just got off the phone with certified Philips shop...they said they will repair it for $100-$130 with a $25 down payment just drop it off and he will call me when its done. Does this sound like its worth it or a rip off?
Sep 07, 2008 | Philips 27PT543S 27" TV
Televison & Video Logo
83 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
