Question about Sony Playstation 3 (PS3) Console
No signal My ps3 with my high definition is not getting a signal to my t.v.
  • 3 Answers
You must 'reset' it. to do this, switch it on, have the hi-def cable plugged in, hold the eject button down for 3-5 seconds till it beeps. then you should have no problems. precise instructions are in the quick reference guide.
Posted on Mar 09, 2009
Im trying to connect my ps3 to hp vs15. i really need help!
HP VS15 model does not support HDMI cable input. (high definition multimedia interface) It only supports VGA (blue) analog signal only.
Hope it helps.
Oct 03, 2014 | HP vs15c Monitor
Freezes seconds after i turn it on and screen is all different colors
Try unplugging and replugging all the parts of your ps3 (fixes a lot of startup problems). Im assuming your are using an hdmi cable so you can get high definition (it could be this cable). Try to run it with the original non high definition cable to see if you have a faulty hdmi cable (the older ps3's always came with one but I am not sure about the newer ones)
Oct 17, 2013 | Sony Playstation 3 (PS3) Console
When I first bought my PS3 I didn't own a HDTV so I chose the low quality setting. Now I have a HDTV and I would like to know where do I go in the PS3 setting to change this so i have better quality...
If you want to have a High Quality Graphics on your HDTV you just need to use a HDMI cable or Component Cables that transmit High Definition Quality of Video. Settings of Video will automatically be adjusted. HDMI Cables transmit both high def video and audio signals.
Thanks for using Fixya.
Jan 31, 2011 | Video Game Consoles & Games
How can i hook up a ps3 to a tv
"These are the optional uses of a Playstation 3, not just playing video games this is a lot cooler. Video connections on a Playstation 3, now this is the back of a standard Playstation 3. I'll show you really quick; we have our power, AV outs, digital audio, LAN for internet, HDMI out so pretty much if you want to get high definition picture quality you're going to have to go out and get yourself a HDMI cable. It will go from HDMI the Playstation 3 to the back of your HDTV, that is your HDMI cable this will carry audio and video in one cable. Of course if you want to go on the internet you have the choice of the wireless if you do buy a wireless, if not you can just plug in your inthernet cable right there. We'll skip the audio for now cause that is the next chapter and we'll go to the EV out, you have two options here if you still want high definition video and you don't have HDMI capabilities on your TV you can still go component. If your TV will allow it, component is the RGB that is your red, blue and green cables so with these cables you can still have a high definition signal broadcast to your TV through this output right here. If you are using the standard TV standard definition you don't have the capabilities of high definition yet it doesn't matter you'll get there. Just go ahead and grab one of the standard cables which is your RCA cables and this will be your yellow, white and red. This of course yellow is for the video, white is for your left audio and red is for your right audio so with these cables you can plug up to any standard TV even a high definition TV but only give you standard definition picture quality. So these are the video connections on a Playstation 3."
Please rate the solution. Thanks for contacting Fixya.
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
720p is putting out signal of 480i or p only
Your Tv has its own settings for high definition.
Look in your manual for appearance setting and turn the tv to 720p high definition.
That should be enough. OH! And make sure your PS3 is set for HD output too! My HD tv downconverts occasionally when the Uverse box shuts off and defaults to low def output.
Feb 03, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Playstation 3/blu ray player and I don't know how to get hi def video on a samsung hln467w
Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Ps3 to gateway fdp1760 frequency out of range dvi to hdmi cable
what Frequency is the monitor set to run at ? u will get that mesg whan the monitor is receiving a signal that is greater than what it can handle say ur monitor can take 1024x768@60hz from ur PC and maybee ur PS3 is sending 720x720@100hz so ur monitor can handle the resolution but not the refresh rate that would be why u get that message
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Unable to get ps3 to play when hooked to receiver
The audio inputs on the receiver need to be set to receive the Optical signal on the switch you set the ps3 to. ie Game, DVD, AUX. Each switch needs to be set to receive the audio signal coming into it. Usually on the remotes setup feature.
Feb 10, 2009 | Denon AVR588 Receiver
High definition lead into ps3
try resetting the consoles setting to default,you can acquire this by just putting your finger still on the power button for lets just say 5 secs.until you hear it beeps.then remove your finger.let me know what happens
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
