Question about 1995-1997 Yukon Ignition Starter Alarm Switch
Gmc yukon shuts down after driving for a long time when chech fuses found that the ecm1 fuse is blown when checked found the the ignition fuse blows after surge test
  • GMC Master
  • 2,359 Answers
The first thing you should do is to locate the oil pressure switch/sending unit.
This switch serves two functions.
1) provide oil pressure reading
2) disable the fuel pump relay in event of oil pressure loss.
When this switch is failing to provide the correct pressure to the ECU. The wiring harness can overheat and eventually create a short.
ECM1 fuse blow is because the harness is grounding/shorting.
DO NOT drive the truck until you change the oil pressure switch.
After you change the switch,you should spend sometime to inspect the wiring between the fuel pump relay,ECU and fuel pump.
Please post up day on the comment window/page.
I will follow up on it later.
Good luck.
Posted on Aug 03, 2009
2002 GMC Yukon blows the TBC 2A fues when headlight switch is turned on
Yukon what ? XL , Denali , 2 or 4 wheel drive ?
My GM service info shows it as a 10amp not 2amp
TBC Fuse #60 10A is fuse #60 same yours ?
May 10, 2015 | GMC Cars & Trucks
Front HVAC fuse keeps blowing
Could be a bad ignition switch.. needs to be checked by a professional.
Feb 05, 2013 | 2001 GMC Yukon XL
Backed out drive.engine died,cranks good but no fire at any spark plugs,fuel pump not working either.tried to hook up scanner ,wont connect, just says linking error
The fact that the scanner will not communicate with the computer,no spark,fuel. tells me this is probably a power issue check all the fuses underhood and on left side of dash with ignition switch on, paying attention to the ones marked ecm1 ecm2 i suspect you have a wire rubbed thru somewhere and backing out of driving you bumped on the curb and caused it to short out. if you find a blown fuse follow your harness and see if any signs of rubbing thru this is time of year mice look for a warm spot so could have had a little late night snack on your wiring!!! let me know what you find and we will go from there
Oct 06, 2011 | 2002 GMC Yukon XL
My GMC Yukon will not start. Tested alternator, battery and starter - all are fine
IF DASH LIGHTS LIGHTING UP.PROBLEM GOT TO BE IN STARTER RELAY OR FUSE, THE CAR COULD BE IN THEFT SECURITY MODE.WHICH WILL DISABLE STARTER AND FUEL PUMP.HAVE CAR CODE SCANNED FOR THEFT SECURITY MODE.IF DASH DONT LIGHT UP WHEN YOU TURN IGNITION KEY.YOU COULD HAVE BAD BATTERY CABLES.LOOK FOR BLOWN IGNITION FUSE.IF FUSE OKAY, YOU COULD HAVE FAULTY IGNITION SWITCH.
Jun 23, 2011 | 2003 GMC Yukon
My 2005 Yukon AC blower is not blowing. THe
There is a service bulletin for this problem which replaces the blower resistor and connector. Mine had the same problem while on vacation. No fan speed control, and when it did work, the fan would keep running after the vehicle was shut off. Mine is currently in the shop getting the service bulletin installed.
May 31, 2010 | 2005 GMC Yukon
2002 Yukon horn does not work, where do i find the fuse, I know n
check the fuse box under the hood. i checked the one on the inside of door w/no luck also. i found a larger gray one there that was labeled horn
Apr 02, 2010 | 2002 GMC Yukon XL
Ecm fuse keeps blowing
just fixed this problem, change your fuel pump module, fuel sending unit shorts out on fuel level swing arm blue wire... unfortinately you must replace it as unit because of the design, fuel pump and tank guage fuel level sending unit are a one peice item, fuel tank has to come out to change unit, about a $ 700.00 repair too... fuel pump module runs about 350 to 700 $ depending on aftermarket or factory, try to find one with a lifetime warranty even if it is $ 50.00 more worth it..labor is about $ 250 to $ 400 depending on shop labor rate... definate problem though I ahve no doubt, common problem on GM... please rate my help, thanks...
Aug 06, 2009 | 2002 GMC Yukon XL
2001 Jimmy shut down while driving. The ECM1 fuse blew. Replaced fuse and it blew. disconected circuits related to ECM1 fuse. reconected one circuit at a time. Fuse did not blow and Jimmy started. Why?
It's a single wire terminal with plastic connect sensor from the engine block.
Good luck.
May 21, 2009 | 2001 GMC Jimmy
Climate control 04 yukon denali
I would try resetting both sides. i.e., Set both sides to hot, then back down to cool. Also check your fuse. I am not sure, but would think, you have a fuse for all these different items. It is time consumming, but look through and find your blown fuse. Hope it helps.
Jul 14, 2008 | 2002 GMC Yukon XL
1995-1997  Yukon Ignition Starter Alarm Switch Logo
467 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
