Question about Gateway M305CRV Notebook
The sound on my laptop stopped working, It just went out
When I went to the control panel to try to see if I could fix the problem I did a test and my speakers worked but when I tried to listen to my music on itunes it wouldn't work
  • Timothy Bright May 11, 2010
    Have you tried reinstalling itunes. Does sound work anywhere else like Windows media player, a game or DVD. Please let us know if this fixes the issue.
  • rlehman
    rlehman May 11, 2010
    check to see if you don't have mute checked in the sound control panel.
Coby NBPC1023XPPNK Netbook sound is not working
Try restarting your laptop and check your sound ,if the problem persists.
Follow the steps below ,assuming that you are using Windows 7 :
1. Go to Control Panel from the Start-Menu.
2. Click on Sound on the window that opens up.
3. Check whether the default device is correct ,and do a "test sound".
4. If the problem still persists ,contact your hardware support.
Thanks
Nov 09, 2013 | Coby NBPC1023XPPNK Netbook
Skullcandy repair centre
restore using the utility system restore go to control panel, and put the last day that you know was working good.
However you can use cleaner contacts solvent and fix it. Open in control panel the icon sound and use the tabs for headphone, and test the troubleshooting.
You mus sure that you headphone is good, try to test in another computer or CD, DVD. etc
God bless you
Jul 17, 2013 | Computers & Internet
The sound just stopped working on my dell latitude d600. it worked just fine then it just stopped working. how do i fix this can you give me step by step instructions. i went into control panel n went to...
right click on computer and go to properties...then you will need to click on the hardware tab..next click on device manager...here you will see all the hardware connected to the computer...look for the sound and audio device...click on it....then click on the drivers tab...try updating the driver, or you can re-load the driver...if reloading the driver does not work, then there may be an issue with the mainboard..you can go to the dell site to see if there is an update for the motherboard
Feb 10, 2011 | Dell Latitude D600 Notebook
Headphone jack works but no sound
I had this problem too, only there was zero sound, even when I clicked Test. I know the jack is good because it's never done any of the typical crackling or cutting out when the cord is pulled in a certain direction, etc. - I knew it had to be a setting of some kind. So here's how I solved this particular problem:
[N.B. - This is in Windows 7 OS]
I went into Control Panel -> Hardware & Sound -> Sound -> Manage Audio Devices.
In the popup window's Playback tab (which comes up by default,) I right-clicked on Headphones, then clicked Properties. The new popup window's General tab comes up as default; I clicked on the Levels tab, where there's a slider control for headphone volume. For whatever reason, this was set to 0. I changed it to 100 and I immediately got sound. 'Clicked OK, and exited Control Panel.
Apr 09, 2010 | Toshiba Satellite A215-S4747 Notebook
I have a sony viao and the sound sometimes works
formate ur laptop it will rectifye ur problem
Jan 26, 2009 | Sony VAIO VGN-FJ270/B Notebook
Aspire 5630 laptop sound does not work.
hi sir
go to the ]
start>
control panel>
soung and devices>
voice>
test hardware>
it work's dont forget to fix..
Sep 02, 2008 | Acer Aspire 5630 Notebook
Gateway M305CRV Notebook Logo
891 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
