Weller Standard Tip: 7200 Logo
A
Anonymous Posted on Apr 11, 2013
How do you re-tin the soldering tips - Weller Standard Tip: 7200
1 Related Answer
Anonymous
  • 104 Answers
  • Posted on Feb 09, 2009
SOURCE: tinning tips
Flux the tip, heat the iron, apply solder all over the tip and wipe, while hot, the solder off with fine steel wool.
If the solder is flux core, no need for additional flux
Good Luck
Blowing off fan I knocked of 2 wires to power button how do i hock them back up to mother board.
pinpoint of liquid solder after area and tips of wires are cleaned.best to solder wires first called tinning to put solder on tips of wires. direct hook wires to board. clean under fan and cooling fins first.
build a different plug use lots of light a steady hand and silver solder with flux core with a fine clean tip of soldering iron.gotta be quick and dont let solder get on other areas or short circuit anything else.
2answers
TIPS BURN OUT
It's better to get a soldering station instead.
1helpful
Raccordement fil d'antenne sur circuit il est coupe et je ne sais ou le souder
Step 1:
google translated
antenna wire connection on the circuit is cut and I do not know where the weld
you might need to solder it
You attach wires to printed circuit boards (PCB) in a process called soldering. You heat the wire and PCB pad, melting the solder wire and allowing it to flow onto the wire and pad. The solder wire used is typically a lead-tin alloy although in some special cases, silver is used. Soldering a wire to a printed circuit board may be part of making, repairing or modifying the board or connecting it to another device.
Clean the pad on the circuit board where the wire will be attached. Gently rub the eraser on the pad until it is clean and shiny. Strip about 1/4 inch of insulation from the wire. Tin the end of the soldering iron by melting a small amount of solder onto the iron tip. Heat the wire end with the soldering iron for a few seconds and briefly touch the solder wire to the bare wire, just long enough to melt the solder, and let it flow into the stranded wires. This is called tinning the wire. Tinning the wire is not necessary with solid or single strand wire. Insert the wire end through the hole in the circuit board pad from the top or component side of the board. Bend the end of the wire slightly to prevent the wire from falling out while soldering but do not let the wire end touch any other component lead or another pad on the circuit board. Apply the soldering iron tip to the wire end and solder pad at the same for a few seconds until the solder used to tin the wire end melts. Apply just enough new solder to make a dome-shaped puddle on the pad that covers the hole and the wire. Remove the iron from the pad but do not move the board for a minute. Cool the new soldered joint and do not move the board until the solder hardens. Clip the wire end off with the wire cutters. The wire is permanently attached to the printed circuit board.
Soldering Guide http://www.kpsec.freeuk.com/solder.htm b> b> b> How to Solder to a Circuit Board: Skill Set (with Video)
http://www.popularmechanics.com/cars/news/4213423
Iron does not get hot enough melt solder. it used to. can I fix it?
try reshaping the tip to a dull point with a file or grinder. Then heat it up and apply solder onto the bare copper tip coating it completely. you can clean the excess off with a wet sponge. This is called "Tinning" tthe tip.
Good Luck!
I just plugged in my new weller 8200pk soldering gun and the tip bubbled up. doesnt seem normal, what is wrong? its the tip it came with.
Was it copper that bubbled up or just some kind of covering? If the latter, just scrape off the residue, then tin the tip as normal. If it was the first, it would have been a flaw in the copper--just replace the tip with a new one. It's hardly worth trying to get warranty on it. Hope this helps!
How do i use this product(Weller model Standard 7200)?
You need the nuts that hold the tip in the iron--slide them on, then bend the ends sideways with pliers and leave about 1/4" sticking out sideways. Be sure to make the upper and lower bends in the same direction. Be sure to tin the new tip with solder when you first heat the tip. Hope this helps!
8helpful
Weller 8200 series soldering gun sometimes fails to heat; tightening screws and/or gently spreading arms often helps. Is there a permanent fix?
There is constant maintenance needed to keep soldering, the key ones are the tip fastening nuts, and the tip itself. The tip eventually needs sanding and immediate retinning, Clean with damp rag during and after each soldering event, and heavily re tin at end of event.
We can't keep the tip tinned, what do we need to do?
Clean the end of the tip with a smooth file down to bear metal heat it up and retin the end with fresh solder. Are you using multicore solder with resin flux ? some old solder does not have any flux in it.
1helpful
Weller D550 fried brand new tip
are you sure you bought the H.D. tip this is the big gun
Tinning tips
Good Luck
Top Weller Welding Tools Experts
Jesse Walters
Jesse Walters
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
