Question about Brother MFC-8460N All-In-One Printer
Message keeps paper tray is full and it is full.
Status light keep flashing and message says paper tray contains no paper when it is full. Tray had been removed several times and have unpluged machine, still message says paper tray is empty. Please help.
  • steve12866 Mar 16, 2009
    keeps flashing---out of paper
  • user456 Apr 14, 2009
    I have the same problem:
    "Status light keep flashing and message says paper tray contains no paper when it is full. Tray had been removed several times and have unpluged machine, still message says paper tray is empty."
    My printer is less than 3 years old, and even I tried taking out the casette and look at the white gear on the left, there is no help.
    I found that on right of the casette the indicator of whether the paper is full or empty, it fails to work too - when the tray is empty the indicator shows full. How can I solve this problem of status light keep flashing "no paper"? Will it help if I replace the casette bay?
    Now with the "no paper" signal on the printer cannot even function. Please help! Many thanks!
  • 215 Answers
Pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Posted on Mar 27, 2009
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Keep getting misfed paper message. can't see paper
Check the paper tray. The part at the end of the paper might not be keeping the paper pushed to the front of the tray. Remove the tray and check the rollers that feeds the paper. They might be slick. Clean them with some WD-40 sprayed on a rag.
Nov 22, 2009 | Ricoh CL4000DN Laser Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
GESTETNER DSc 38
it may be one of two problem, to start off with try using one of the other trays or the manual feed. to see if it's just that tray or the machine. you may need to cancel all jobs in the printer before starting and also keep the main tray open. let me know what heppens.
Thank You,
Mikey
Mar 19, 2008 | Ricoh Aficio AP3800C Laser Printer
Paper tray full message and not printing
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
Dec 26, 2007 | Kyocera FS-4000DN Laser Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Brother MFC-8460N All-In-One Printer Logo
558 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
