Question about Acer AL2216WBD LCD Monitor
I have my HP Pavilion hooked up to my new Acer al2216W monitor. The image comes up on the monitor but keeps flashing on and off constantly. How do I make the screen stay on?
  • 298 Answers
Video Card problem. This can be caused by your onboard video card or a separate video card installed on your AGP or PCIE slot. Either way, try changing your display settings first. Set it at a lower or higher refresh rate and lower or higher bit and resolution settings.
Posted on Mar 15, 2009
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
Apr 26, 2015 | Acer AL2216W LCD Monitor
I have an Acer Monitor AL2216W and it will come on, the Acer name appears, then no signal and then the green light goes to orange. Is this the power supply or what?
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Here is the inside of your monitor:
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
Dec 22, 2011 | Acer AL2216W LCD Monitor
I have acer lcd al2216w on the lcd there is a green line comes between my screen it cant be remove i dont not how he comes please tel me what i do change a new lcd or what it can repairable or not
Hi there reinstall the display driver & then give a look. If you face same problem then its may problem with your display driver or in the monitor.
Jan 18, 2011 | Acer AL2216W LCD Monitor
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
Monitor lcd acer al2016w 20" letters and image are fuzzy,,why?
I also have an Asrock motherboard (M266A) and have the AL2216W. The image and text is also fuzzy. I did improve it a by by unplugging/replugging all of the connectors on the back of the computer. I believe my mouse had a somewhat loose connection and this was causing interference. I can actually create interference on screen by moving my mouse up and down.
These Acer monitors seem to be very sensitive. I also tried this monitor on a old Desktop with Win98 and another new laptop with XP and it looks good on those computers, but not on my Asrock based system.
Nov 30, 2008 | Acer AL2016W 20" LCD Monitor
Ghosting of the image
no it is a board replacement at best, so i would look into replacing the vga board or getting a new monitor and selling the damaged one for parts with the issue listed
May 11, 2008 | Acer AL2216W LCD Monitor
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Horizontal banding that looks like Interference
i would take this in for a service check could be issues that need resolving from a service standpoint not a simple driver or resolution fix
Dec 18, 2007 | Acer AL2216W LCD Monitor
Acer AL2216WBD LCD Monitor Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
