Question about Brother MFC-8460N All-In-One Printer
Message keeps saying out of paper and paper tray is full.
Take and reload paper tray and even unplug and replug and reload paper tray. Keep receving message that paper tray is empty. Please help.
  • smoctezuma Mar 25, 2009
    I am having the same problem I put paper in the printer and it is still saying OUT OF PAPER I also shut it down and still nothing
    Problem Solver:
  • 3 Answers
Ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Posted on Mar 09, 2009
Keep getting "load paper message" when tray is already full
Make sure the tray is closed correctly and try to reset it by unplugging it, then try it. Look in your manual too for troubleshooting ideas. Good luck!
Mar 02, 2016 | Canon PIXMA Office Equipment & Supplies
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
My printer keep saying "
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
Nov 09, 2010 | Office Equipment & Supplies
Keeps saying out of paper but is not how can I reset, I have tried reloading paper, and have turned of power, and disconected network cable, then restarted but still no use. How can I make a default reset
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing.
Aug 19, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
LSU error message
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
ImageRunner 2020 paper tray open warning - cannot fix
Are you check the sensor flaper for paper presence?
It is located above paper in pick up assy.Whe you remove the drawer you should be able to see the black flaper hanging from above.
Apr 08, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Check paper tray - reload paper
Your paper sensor actuator arm is most likely broken or out of position, or you may have a dirty sensor if you are in a dusty environment. If you look in the machine with the tray out, you should see a small (usually black) piece of plastic hanging down. You can also take the toner and drum cartridge out and turn it on its back to get a better look. If it's not there, it's probably broken off.
Feb 07, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother MFC-8460N All-In-One Printer Logo
761 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
