Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Starter removal how do you remove the starter from a 1999 sportster 1200
    Problem Solver:
  • 5 Answers
It's quite a process to remove a starter on a sportster. I changed one for my friend on his 03 sportster. You have to take alot of stuff off to get to the bolts that hold it on. Can I suggest getting a service manual for the bike. Trust me it's worth its weight in gold. I've done alot of work on my sportster and my friends sportster and would never attempt anything without the book. As far as the starter, From what I remember, I had to remove the exhaust pipes then the primary cover, and I'm sure there were more parts, but you need to know what gaskets you will need to replace. Good Luck. And go get the book. I got mine at Barnes and Noble. and my friend got his at the Harley dealer. Have fun.
Posted on May 08, 2010
How to remove the starter motor on 2005 Harley sportster
Hi Hubert, I am sorry you can't find the first and best tool you ever bought for your Harley Davidson but despair not for a mere $6.50 you can download another one. For more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
evo sportster starter removal from evo sportster problem 11
Servicing rebuild your starter motor
Harley Davidson Manuals Mark Workshop
Oct 31, 2015 | 2005 Harley Davidson XL 1200 C Sportster...
How do i replace a starter on a 2005 harley 1200 sportster
Disconnect the battery and then the wires on the charger. Drain the transmission (left cover). After that, you can remove the shift lever connection and the clutch cover. Disconnect the clutch cable from the clutch assembly. Now you can remove your complete primary cover. After all that you will want to remove the two screws that hold the starter to the engine. Then simply put everything back in the reverser order using all new gaskets and seals and fill the transmission back up w/the proper amount and weight of oil.
Mar 07, 2015 | 2005 Harley Davidson XL 1200 C Sportster...
What are the basic procedures for removing the starter on a 2004 HD Sportster 1200 custom?
First disconnect the battery negative cable. Then drain the transmission/primary and remove the primary cover and then remove the battery cable at the starter solenoid and the solenoid wire and then undo the starter mounting bolts in the primary case and remove the starter from the right side.
Sep 21, 2014 | Motorcycles
I have a 1200 sportster 1200 carborated evo and the speedo quit working . Do I need to replace the ecm or is there a fuse for it????
Hi Anonymous, try cleaning your speed sensor located on top of the transmissions right side between the top cover and the chrome starter end cap on Twin Cams and on top of the engine case between the rear cylinder and the starter motor for Sportsters. Remove the the bolt that secures the sensor and pull it out of the transmission. Inspect sensor for obvious damage and repace if necessary. If sensor has no damage then wipe clean any obvious contamination like micro fiberous material with a clean rag and reinstall, torque bolt to 8 ft lbs. Please visit the website below for more information and good luck. Harley Davidson Sportster error codes and how to access them
Oct 14, 2013 | 2002 Harley Davidson XL 1200 C Sportster...
Cant get side casing off to get to starter motor out on my harley 1200 sportster
Take the derby cover off. Remove the small spring and the lock nut for the clutch adjuster. Turn the clutch adjuster screw clockwise while at the same time gently pull the cover off. This should do it.
Jun 25, 2011 | 2005 Harley Davidson XL 1200 C Sportster...
How do you take out the starter?Does the engine has to be taken off the frame?.
No, the engine does NOT have to come out of the frame.
First, disconnect the battery. Drain the primary cover, remove the shifter, foot peg, loosen the primary chain adjuster under the outer cover, whatever needs to be removed depending on your model Sportster to get the primary cover off.
From the right side of the bike, remove the exhaust system and whatever you need to remove to get the starter off. Disconnect the large battery cable and the single wire from the starter.
Back on the left side, there are two large bolts just above the clutch assembly, remove them. They may be different lengths so watch for that. Remove the starter.
Good Luck
Steve
Sep 14, 2010 | 2004 Harley Davidson XL 1200 C Sportster...
Harley Davidson Sportster starter removal?
1997 HARLEY DAVIDSON SPORTSTER XLH 1200
STARTER REMOVAL
1. REMOVE LEFT SIDE COVER
2. REMOVE NEG. BATTERY CABLE FROM CRANKCASE TO PREVENT ACCIDENTAL STARTUP
3. REMOVE POSITIVE BATTERY CABLE
4. DRAIN TRANSMISSION FLUID (5/8" SOCKET)
5. REMOVE PRIMARY COVER (IF YOU'RE UNSURE OR IT'S BEEN AWHILE - PLEASE CONTACT - I CAN PROVIDE INFO)
6. REMOVE REAR EXHAUST
7. REMOVE 2 STARTER BOLTS (5/16" ALLEN)
8. REMOVE STARTER
9. REMOVE GASKET
10. SLIDE BOOT BACK AND DISCONNECT THE POSITIVE CABLE FROM BATTERY (12MM)
11. DISCONNECT STARTER SOLENOID POSITIVE LEAD TO STARTER
12. LOOSEN WIRE BAND NUTS 3/8" SOCKET
If anything you're unsure about or been awhile just comment below or reach out. The primary cover has a few quirks to get off - can go further with you if needed. All The Best, Justin Lee
17 South Industries, LLC
Aug 10, 2010 | Maisto Harley Davidson 1997 XLH Sportster...
What is the procedure for replacing the starter on a 1996 Harley Sportster 1200?
first remove the primary cover to get to starter bolts,then remove rear exhaust,then the battery pos. lead and solenoid from starter
Mar 26, 2010 | Harley Davidson XL 1200 S Sportster Sport...
1997 Sportster won't start
Check the battery, try jump starting with another battery or power source, removing the plug is reducing the compression making it easier for the starter to spin. I suspect your battery or starter doesn't have the jam to spin the motor.
Apr 05, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
245 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
