Question about Vivitar ViviCam 35 Digital Camera
My vivatar keeps switching its self off and not holding the power. I have replaced the batteries a number of times but I just can seem to use it at all. Please help me
    President:
  • Vivitar Master
  • 1,734 Answers
Did you check the manual? You can get it from http://manualfox.com
Just send them a request.
Posted on Mar 28, 2009
My samsung tablet gt-p5210 keeps shutting down especially when i go to play some games help
Check this link for a simple fix for the problem that you are experiencing.
Dec 17, 2014 | Samsung Tablets & eReaders
I have a Tripp Lite G1010USB uninterruptible power supply that only powers the surge surge-suppressor outlets and not the battery-backup outlets. Unless the UPS is unplugged from the wall, and then i
You know they have a TWO YEAR Warranty ?
Sounds to me that it is faulty (one of the relays or switches is not providing 'through' power to the supposed 'backup' socket when the AC power is on.).
Have you followed the manual ?
available here http://www.tripplite.com/support/model/mid/G1010USB
Have you done a 'self test' ?
'To Run a Self-Test: With your UPS plugged in and turned on, press and hold the MUTE/TEST button for two seconds. Continue holding the button until the alarm beeps several times and the UPS performs a self-test. See "Results of a Self-Test" below.
Note: You can leave connected equipment on during a self-test.' see manual
If the LCD does not give you the answer then it is faulty. Seems like something went faulty on restarting your UPS in the morning.
Seems like plenty of help available from this companys' website.
Sep 13, 2014 | Tripp Lite Ups Battery Backup G1010usb
My ooutdoor tecnology tags are not charging on my mac when I plug in I keep swicthing plug in port . Any Ideas??
How old are they and have you left them on the charger for long periods of time? The batteries are small and dont last long if they are old or constantly over charged.
Sep 09, 2013 | Outdoor Technology Ot Bluetooth Tags...
As my Xerox M-24 powers up, and gets to the fourth white dot during the start up self tests, which flashes three times, then the machine seems to turn on for two seconds, then gives the fault stating...
Try this with the network cable unplugged.
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
If it doesnt correct the problem the network board ESS has failed.
Mar 11, 2011 | Xerox WorkCentre M-24 Color Copier
Stilleto 2 keeps shutting down
It may be a problem with the power switch, I too had this problem. It seems like the power switch is stuck in "down" position as if you were holding it. I remove my battery cover (along with the battery) and gently jiggle the switch up and down to "loosen" whatever may be sticking it in place and it seems to work. I have encountered this problem several times. I did not send it out for repair. It works fine for me (knock on wood).
May 13, 2010 | Sirius Stiletto 2 Satellite Radio Receiver
Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Feb 19, 2010 | Tripp Lite OMNIVS1000 UPS System
Starting and once started won't run
The problem seem to involve a number of circuits, I would suspect the Key switch as it supplies power to all affected systems. The dieing on release of the clutch is usually the kickstand safety switch. If the kick stand is not up, and the bike in gear, then when the clutch switch detects release is kills the engine so you don't kill your self.
Check or replace these switches.
Hope this is of some help.
Ed
Apr 26, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
It seems i have over charged my sand disk player so right now when i switch it on it says battery too slow and then it shut down it self, please i need a help to this problem .
Hi teddyabout,
There are few reasons your SanDisk Player is acting up. Here are some things to try out.
Make sure the HOLD switch is turned off before you power up your player. This will sometimes cause errors in booting.
If that doesn't work you can try a soft-reset by holding the power button down for 15 seconds then try turning the player on normally again.
Finally, if you are brave enough, you can take the battery out of the player to force a complete reset of the player and battery. This is done by taking the four screws out of the back of the player and removing the battery. After 30 seconds, put the battery back (be sure the it is seated properly) and replace the screws.
Good luck
-SHG
Jan 14, 2009 | SanDisk Sansa e200 MP3 Player
Vivitar ViviCam 35 Digital Camera Logo
35 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
