Question about Brother MFC 7840W Printer
Brother MFC 7840 W blank screen
Just bought a new MFC 7840. not yet connected to network just using it to scan and fax. started it and faxed couple docs. next day the lights went off so the printer went off and came back on but no display. tried evrything but cant see anything on the display just green blank background. Any help appreciated.
  • MasonMcD Mar 24, 2009
    I have the same issue. For a while, I was able to unplug it, and hold down the "stop/cancel" button for 5 seconds after I plug it back in, but now that doesn't even work.
5 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: Brother MFC 420 CN
the brother printer is not a good brand i also have a brother mfc 3220cn and it gives the same problem, what you have to is unplug the machine and let it stand for about 2 days take out the cartridges and clean the printing with air replace back them and plug in.that should remedy your problem.i urge on you never to buy brother printers.if you buy them get a bottle of phensic along with it.good luck my brother.
Posted on Apr 04, 2007
  • 320 Answers
SOURCE: brother 7840 all in one--fax
using the adf feature face up good luck brother sr tech
Posted on Jan 24, 2009
BubbaGuru
  • 70 Answers
SOURCE: ! Unable to print 36
here is the solution according to brothers website
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000012648&Sympt=How+do+I+clear+error+message+Print+Unable+36%3f&Model=1208&ProductGroup=1&ProductID=HL4070CDW
Posted on Mar 23, 2009
SOURCE: my fax BROTHER MFC-215C does not print after
The solution, finally, was very simple: To disconnect the mains voltage, for several days, from BROTHER MFC-215 .
After that, I was successful to receive and print the incoming faxes.
Thank you very much for your willing to help.
jacobr05
Posted on Apr 08, 2009
  • 468 Answers
SOURCE: how to scan with brother mfc 7840-w
Usually with new Brother mfc 7840-w you get also CD with PaperPort 11 LE. It is very good program for scanning and editing images.
Posted on Oct 24, 2009
"Cannot be contacted over this network" after trouble shooting.
USB or Bluetooth? Put network settings in copier that match your inernet settings in Windows.
Nov 15, 2013 | Brother MFC-8480DN MFC8480DN...
New computer is Windows 7 - 64 bit Printer is Brother MFC-8820D. Printer works fine - computer does not recognize the scanner feature of the MFC. Have tried both USB and LPT1 connection to the new...
I lost my network fax and scanning when I upgraded to Win 7 as Brother had no support for Win7 and this printer. Very disappointing.
However, I recently downloaded the MFC-8370DN install package from the Brother website and installed it on my Win7 64 bit Asus laptop. The installer couldn't find my MFC8820DN, but I manually entered the IP address (192.168.0.100 in my case). The install completed cleanly, after a reboot I can now start Brother Control Centre 3 and scan and fax from my 8820DN over the network. All good, no need to buy a new printer just yet...
Apr 26, 2011 | Brother MFC 8820D All-In-One Laser Printer
I am using a printer of brother mfc and i can not understand how to fax from it
The default setting on Brother MFC printer is Fax. Meaning you will usually see the Fax Button lit with a green light. (If the fax button is not lit, just press that button to get it lit.). Put the sheet of paper you want faxed with the side you want sent face down. Now press the OK button. The screen will ask you to enter the Fax number. Key in the Fax number. Press start. The printer will start scanning that page. Once the first page is scanned it will give you 2 options. You can press 1, if you have more pages to send to the same Fax number. or you can press 2. This will tell the printer(Fax) it is just a 1 page document and the machine starts dialing. Wait for the fax completed message. Please make sure that the machine is connected to a working phone line before you start.
Aug 13, 2010 | Computers & Internet
I have lines in the fax quality of my MFC 7840 N
Fax out or received copy ? Clean the scanner glass.
Dec 10, 2009 | Brother Office Equipment & Supplies
Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Nov 24, 2009 | Brother MFC 7840W Printer
How to scan with brother mfc 7840-w
Oct 24, 2009 | Brother MFC 7840W Printer
Brother MFC-7840W fax will not work
Plug a regular phone into the wall jack and listen for a dial tone.
Phone cord should be connected to the LINE port of the fax.
Do you have DSL?
Unplug power cord for 10 seconds.
Oct 17, 2008 | Office Equipment & Supplies
Not able to send fax to an eFax number
I've had the same problem before. I don't know if it will solve your problem directly but I can offer a work around or two.
1. I have an efax number but with a company called callwave.com , I fax stuff to other customers using callwave and my MFC 7820n completes each fax successfully. So if you can get yourself a callwave efax number you can fax to yourself and forward fax as an email to your intended party.
2. Or, you can use your mfc 7820n to scan your fax docs as a pdf directly to your computer and then emailing them to your intended party.
Unfortunately it might be a brother issue because at the office when I use the hp fax machine instead of the brother machine, the hp faxes to efax numbers without a problem.
Sep 05, 2008 | Brother MFC-7820N Printer
Error Message: Scan Unable A6
did you get the solution to the problem u mentioned
Feb 21, 2008 | Brother MFC-8220 Fax
Brother MFC 7840W Printer Logo
224 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
