Question about Dell E193FPC 19" TFT LCD Flat Panel Monitor
Need to remove dell e193fpc flat panel covers to repair
Need to know exact procedure for lcd monitor cover removal.
First remove the stand. Then at the bottom of the monitor there are two small openings an inch or two from each edge. Starting there with WIDE flat blade screw driver (or a couple of them) it IS possible to pop the catches that hold the back of the case to the front. You have to go around the case very carefully popping each catch and preventing the areas you have opened from becoming re-latched. I found some wood popsicle sticks good for that.
If you search for "LCD Monitor Repair" you can find sites that have video's of several Dell models (but not this exact one) any that use the "pop open" case are pretty much similar.
One note after you get inside. The power supply board had the WORST solder job I have seen in a long time. The failure in the unit I repaired was due to open solder joints on the hi-voltage transformers taking out the power transistor's that drove them. It took me two months, but I found some replacement transistors on ebay and after resoldering many of the joints on the board it the monitor works fine.
I attribute part of the failure to the use of Lead free solder which is becoming common in all consumer electronics. It makes for brittle connections that fail easily and there is also the issue of tin whisker growth that will hit in a few years down the road.
Posted on Mar 16, 2009
How to remove the front bezel from a dell e193fpp monitor by hand?
Seek a troubleshooting manual
http://r.search.yahoo.com/_ylt=A86.JyZM1D9XbXgAZOBEDN04;_ylu=X3oDMTByN2lydWw3BHNlYwNzcgRwb3MDOARjb2xvA2dxMQR2dGlkAw--/RV=2/RE=1463829708/RO=10/RU=http%3a%2f%2fservicerepairmanuals.net%2fcomputer-monitor%2fdell-e193fpc-lcd-monitor-service-manual%2f/RK=0/RS=CK8mHx7DCNfOWVMhlLjDV6MvmXw-
Aug 17, 2014 | Dell E193FP 19" Flat Panel LCD Monitor
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
Dell E193FPC 19" monitor display
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
Apr 30, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
Monitor will not start up on off switch is blinking
The problem is actually in the CPU and not in the Ram
This happens due to dust in the Ram .In order to fix the problem try removing the Ram from the slot and fix again after cleaning the Ram and the Ram slot .
If the problem persists try resetting the Bios by removing battery.
please rate me
May 11, 2010 | Dell E193FPC 19" TFT LCD Flat Panel...
How to open the flat screen
Francois, If you really want to remove the pedestal and then rear plastic cover from the front BEZEL, then why don't you visit YOUTUBE and view some video clips of "LCD monitor disassembly" and "LCD monitor repair" to see how to "PART" the cover from the bezel!!! There sure is a lot of stuff to see on YOUTUBE. HINT!!! YOU must protect the LCD PANEL at all times!!! GOOD LUCK, 12fixlouie
Dec 11, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
How do you get the case apart?
chrisc257, Yes, you too, will need to watch some video clips @YOUTUBE !!! Search and view 6 to 10minute clips of "LCD monitor disassembly" and "LCD monitor repair" and stuff relating to "bad capacitors in lcd monitors" . Are you doing this as a SCHOOL SCIENCE PROJECT that you will be graded on? First remove the pedestal stand from the back cover.(screws or some locking TABS) Then remove screws from back cover. If you can see them. then un-snap the cover from the front bezel. Watch how they do it on youtube and be careful not to injure yourself or the monitor LCD panel.. GOOD LUCK GUY, YOU'RE ON YOU'RE OWN NOW!! 12fixlouie
Dec 01, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Dell W1700 picture went out. Still have audio.
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
Nov 29, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Dell E193FPC
Looks like your inverter board is broken.
Similar problem as Neovo F-417 (same chassis) , Look for 715L1283-4 inverter board
Try http://lcdpartsandrepair.com/e193fpc-inverter-power.html
Jun 26, 2008 | Dell E193FPC 19" TFT LCD Flat Panel...
Speaker Bar connection
There are 2 placces on the underside of the monitor for the speakerbar to slide into. For that model You will probably need the external power supply.
Jun 22, 2008 | Dell E193FPC 19" TFT LCD Flat Panel...
Dell 1704FPTt 17" TFT LCD Flat
I used to repair LCD monitor from Dell. There are 4 screws for rear panel and no screw for front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Hope this will help you to get the rear panel off. If there is anything I can help you with, feel free to let me know.
Thank you,
Mar 02, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Dell E193FPC 19" TFT LCD Flat Panel Monitor Logo
1,090 people viewed this question
Alun Cox
