Question about Toshiba 50H81 50" Rear Projection Television
The sound does not work on my 50H81 Toshiba rear projection HDTV, when it's in the HD mode. It was working prior to being moved & was hooked up through a Bose surround system. The sound on the TV works when in the regular moded (digital) or with the DVD or VCR. I've tried new component cables, as well as both sets of HD inputs into the TV. Unfortunately, this does not have a HDMI input for the TV.
  • 111 Answers
Check to see if the comp inputs have a red and black audio input. Those must be connected, second go inside the menu and make sure the inputs match..good luck..
Posted on Mar 09, 2009
I recently got a 51h83 toshiba tv. When i try to hook up my xbox 360 with the hd component cables in the back i get sound but no video. Please help.
WITH THE TOSHIBA 51H83TOSHIBA TV YOU CANT HOOK UP HD CABLES TO THAT SPECIFIC TV FROM YOUR XBOX 360 BECAUSE THE DEVICE ISNT EQUIPPED WITH THAT CAPABILITY
Nov 16, 2016 | Toshiba 51H83 51" Rear Projection...
Video input on the front and back don't work the only one that works is the HD its a toshiba tv model 50h81 can i fix this
if using a box unplug it and set from power and wait, then plug both up and let reboot to see if it helps--if a real problem in the set the cost to repair and the parts that may not even be available end the life of this set..
Apr 16, 2012 | Toshiba 50H81 50" Rear Projection...
Do i need hd cables for an hdtv?
If you want to watch some content in HD you will either need to connect your TV to the computer using a VGA or DVI cable, or connect using HDMI(picture + sound transfer) cable to the computer/DVD... You can connect your TV also using Cinch or Scart cables but you will not have HD resolution. Hope this helps!
Oct 11, 2011 | Toshiba 50H81 50" Rear Projection...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
Shaky picture on my toshiba 50h12
Your ICc may have damaged if display is flickering.
Jan 22, 2009 | Toshiba 50H81 50" Rear Projection...
Want to know how to hook up my lap top to the tv
yes you can run in composit s vido mode and you also need to set up your laptop screen seting to composit out mode.
thanks,
daniel.
Jan 12, 2009 | Toshiba 50H81 50" Rear Projection...
1999 toshiba rear projection tv blinking red light after moving
this might be a tube leak check for fluid on the necks of the tubes with your hand. if none you might have a faulty protect chip- common-
forgot the exact location but it's on the main board, it's a 16 pin chip as i remember and it is a quad op amp. if you hold your finger across the pins underside it will turn on and stay on as long as your finger is there, if so replace the chip
Dec 25, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 Projection TV
youre convergence ICs need to be replaced there are two of them they are both STK392-110 you can get replacement Ics and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
May 24, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81
convergence amp ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 16, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
126 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
