Question about Kole audio QX1-2400D Car Audio Amplifier
I have a 2400 kole audio amp also have 5 EVs connected to that amp, I have had monster power but with in the next week the power I had faded away. How can I get the power I have had back?
    Problem Solver:
  • 8 Answers
You are lacking batterie juice ?
need to replace your stock with a yellow top and
add another to the truck close to you amps !! should work great !!
Posted on Mar 10, 2009
My friend just got a KOLE AUDIO QX1-30000.. he's wantin to know if its a 3,000 watt amp or what because it says QX1-30000 on it??
This is the specs on it:
  • RMS Power Rating:
    • 4 ohms: 1100 watts x 1 chan.
    • 2 ohms: 1800 watts x 1 chan.
    • 1 ohm: 2300 watts x 1 chan.
  • Max power output: 3000 watts x 1 chan.
Jul 01, 2015 | Kole audio Car Audio & Video
My kole audio amp protects when powered
you read amp catalogue there written it briefly.
Mar 27, 2013 | Kole audio Nitric XP4-1000 Car Amp
Just wanted to know what the square boxes on top of my kole audio hk-980-2 amp was.
On the hk 980-2 those boxes are just for looks. I own one of these amps and im runnin 3x30amp fuses in it and it seems to put out 870-900 watts bridged at 14.5volts all day. I have an extra battery and i put 0-4 gauge reducers in mine. I have 2 memphis pr 12s and they sound really good on it.
Mar 08, 2012 | Kole audio HK980-2 Car Audio Amplifier
20,000 watts capacitor meter reading 13.9 with 2 battery & 250 alternator
Hello! The required voltage is 24 volts...which means two 12 volt batteries connected in series...It sounds as if you have two 12 volt batteries connected in parallel...Which doubles the amps and leaves the voltage at 12 volts...Connect the negative of one battery to the positive of the second battery...Then from the positive of battery #1 to the negative of battery #2 is the required 24 volts for the Kole...Guru...saailer
Jan 17, 2012 | Kole audio 20 Farad Digital Car Capacitor...
It worked for a week and now im getting no power to my subs
if it stopped suddenly i would check the fuses and work your way back to the where the remote start wire is attached. if you where pushing it hard the fuse is likely. also check the connections on the amp closely.
Jan 28, 2011 | Sony HK720-4 Kole Audio 4 Channel Car...
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
Kole Q1-3000D Power Supply caps Keep blowin
you need a fuse of 300amps or higher with 1/2aut cable power supply connected to an after market altenator. also make sure the subs are wired properly.
Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
Kenwood KAC-9152D Car Amp
use a multimeter to check for power on the +ve wire, could be your fuse, it only rus a sec when you jumper the remote to +ve because the remote cannot give out the nessary current to run the amp.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Kole audio QX1-2400D Car Audio Amplifier Logo
139 people viewed this question
Top Kole audio Car Audio & Video Experts
David Burbee
David Burbee
Hashim Khan
Hashim Khan
Terry Hair
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
