Question about Kodak EasyShare Z650 Digital Camera
I HAVE A KODAK EASYSHARE C875 ...IT WILL NOT STAY POWERED ON. I
WILL TURN IT ON, THE LENS WILL OPEN THEN QUICKLY RETRACT.. I HAVE CHANGED THE BATTERIES & STILL NO SUCCESS...HOW DO I FIX THE PROBLEM?
  • 3,037 Answers
You probably have bad battery contacts or another electrical contact somewhere inside if this is happening. Take the batteries out and clean the contacts there. Have you dropped this camera at all? If the above doesn't help, then you have some other problem related to the hardware most likely. Some sensor is telling it to shut and it will be best to send it in for repair or get a new one.
Benjamin
Posted on Mar 09, 2009
  • Kodak Master
  • 13,433 Answers
Does the camera give you a error message or just turn off? Turning off might be low battery power. Do you get flashing or a error message?
    Genius:
  • 1,550 Answers
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
When I switch my camera on it will not focus - my
Did he drop it while it was being used?
Also, I assume that you have fresh batteries.
Why doesn't the lens retract when I turn off my camera or extend when I turn on my camera? Question : Why doesn't the lens retract when I turn off my camera or extend when I turn on my camera? Answer : The batteries may be low or exhausted.
NOTE: If the batteries run low on power, your camera may turn off without retracting the lens. In most cases, this is normal and can be corrected by recharging the camera batteries.
In the U.S. and other countries where the Step-by-Step Solutions and Repair tool is available:
  1. Recharge the batteries or install new batteries.
    NOTE: Rechargeable batteries can be charged in the following ways depending on the camera:
    • Remove the batteries and place them in an optional battery charger.
    • Place the camera in a printer dock or a camera dock.
    • With the batteries installed, connect the camera to an AC adapter or to a computer using a USB cable.
  2. For more information, go to KODAK Product Manuals, and select the User's Guide for your camera. To see the battery charging accessories that are available for your camera, go to KODAK Accessories.
  3. If the problem persists, go to the Step-by-Step Solutions and Repair tool.
    • Select Digital camera, camera dock, or digital video camera.
    • Select Lens.
In countries where the Step-by-Step Solutions and Repair tool is not available:
  1. Remove the batteries, then wipe the battery contacts with a soft, clean cloth.
  2. Install the batteries, then turn on your camera.
  3. If this does not resolve your problem, remove the batteries.
  4. Go to Choosing the Right Battery for Your KODAK Digital Camera, then follow the instructions to verify that you are using the correct batteries.
  5. Install new or fully charged batteries into your camera.
    • With the batteries installed, connect the camera to an AC adapter or a computer using a USB cable.
    • For more information, go to KODAK Product Manuals, then scroll down to select the User's Guide for your camera. To see the battery charging accessories that are available for your camera, go to KODAK Accessories.
  6. Turn on your camera.
  7. If the problem persists, go to Eastman Kodak Company Worldwide Contacts for assistance.
Jul 23, 2010 | Kodak EasyShare C875 Digital Camera
Lens won't retract. Camera powers off immediately after powering on without retracting lens. New battery didn't help.
Are you using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
first you need to do make sure the battery is fully charged., now if you if this solution will not resolve the issue it means that the Gear Lens is defective thats why your Lens will not retract and camera will not stay On. you need to call kodak to send your camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EASYSHARE V1253 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
Try helping the camera to retract using your fingers while you turn camera off, try also helping lens to full extent if they don't.if you do not succeed in this simple way the camera lens must be taken apart and reassembled at a repair shop.
Jul 25, 2008 | Kodak EasyShare M853 Digital Camera
Stuck lens
You can restart the camera (power off and on or follow reset procedures) and/or try to get the grit out so the lens can retract.
Jun 25, 2008 | Kodak EasyShare C875 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
I have the exact same problem. Can anyone help?
Apr 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Camera Won't Stay On
hi change the battries good luck
Apr 16, 2006 | Kodak EasyShare V550 Digital Camera
Kodak EasyShare Z650 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
