Question about Samsung Remote Control
Samsung 50in tv trouble getting it started
I turn on tv and it starts what sounds like a downward whine. Then theres some clicking and eventually the three flashing lights. I start it again and it cycles through the same way ending w/ the three blinking lights. After a few tries the tv will turn on and run fine until the next time i try to turn it on again. Its getting longer and more cycles before it will start.
  • 39 Answers
The color wheel is bad. this whirring noise is caused from bad bearings in the 12v motor and possibly broken plastic panes from the wheel. DO NOT KEEP TURNING ON AS THIS CAN THROW PLASTIC PIECES INTO THE LIGHT ENGINE TUNNEL. very hard to retrieve debris from light engine. even small fragments can show up as large blemishes on the screen once the pix is magnified. needs professional service as light engine must be removed and realigned after replacement. mch
Posted on Mar 09, 2009
I have a samsung hln507 and there is no picture. we start the tv, it has a high pitched whining sound, the fan and the color wheel are spinning, but there is no picture. after about 10 seconds the tv turns...
The colors wheel is dead.That why,u hearing high pitched whining sound.The colors wheel is spinning off of is motor axis and grinding it sides walls,that where the high pitched whining sound came from.Hire a tv Tech. for the colors wheel changing,because it requiring to take out alots of the machanicals parts itself,before u can come to the colors wheel itself to change it.
Oct 16, 2010 | Samsung HLN507 50" Rear Projection...
Samsung plasma 50in PS50B550 clicking noise
The clicking could be a loose connecction of the power plug or frrom the main power unit of your TV. Remove your plug and see the ends for burn outs, if so clean and use a different outlet. If not open the set after disconnection and check your main power supply unit for loose connection particularily in the surge protector, the main capacitor, the main drive, diodes or connectors. Wait to hear the sound and use a long insulated rod as a probe to confirm the origin of the sound. Solder or replace the damaged item. Hope this helps . Good day
Jul 22, 2010 | Samsung Televison & Video
Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Nov 23, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung hlm507wx with ''clicking speakers''?
Color Wheel could be a problem also,Ballast Board is what turns Lamp on I would start with ballast Board and if you hear a whinning noise when set is coming on color wheel needs to be replaced then!
Encompass 1-800-638-3328 and you can find some gool deal on E-Bay i got my ballst board for 62.00 and my Lamp for 85.00 CK it out! Just typ in your model number Parts/ or Ballast boards
Sep 27, 2009 | Samsung HLM507W 50" Rear Projection HDTV
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
High pitched whine when the motor starts
Had the same problem. It quit within about 5 seconds after turning the TV off. Replaced the color wheel and the whine is gone. The picture also looks brighter, which may be due to dusting the projection lens with lens-cleaning compressed air (from a can). The color wheel was about $100 from Samsung parts and it took less than 3 hours to replace. See http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ for good info, and be sure to read the cautions.
Aug 07, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung Remote Control Logo
107 people viewed this question
Henry  Thomas
Henry Thomas
