Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Printing... I just wrote a creative narrative for my college prep class, that is 10 pages long. And at first, the paper would just run through. And then I changed the ink even though it said the levels were fine. And then it only printed half of the words on the page. I need serious help!!!!
  • 4 more comments
  • timbedunah Mar 09, 2009
    I have used before. But it is new, I bought it. If that is what you are asking.
    Ok, I did as instructed, but I am still having this problem. The paper will run through, but when it comes out only half the page is printed, and there are lines through the words that do come out. I have checked over the settings, and they seem fine. Is it something with the printer?
    It printed the Windows logo perfectly.
    Nope, this time, nothing came out. I jsut changed the ink things today. Btw. and it indicates they are full.
    Umm, Word. Is that right? I am not good at PC talk. :P
  • Mark Van Skiver May 11, 2010
    New printer? Or have you used before?
    Scholar:
  • 124 Answers
  1. OK Save documents if you haven't already.
  2. turn printer off.
  3. Turn computer off.
  4. wait 60 seconds.
  5. turn printer on.
  6. turn computer on.
  7. goto documents to print
  8. Select file menu at top mouse down to print preview & click.
  9. Check that your documents look correct if the do Print.
  10. If they do not exit goto printer options / properties select letter for paper repeat step 8&9 above.
  11. Should fix you if not contact me back i'll standby.
Please rate if this fixed or helped. Thank you! Good Luck!
Posted on Mar 09, 2009
  • 2 more comments
  • Mark Van Skiver Mar 09, 2009
    1. select start menu.
    2. open printers & fax.
    3. Right click on printer.
    4. select properties.
    5. print test page.
    6. Let me know what happens.
    OK.
    1. Open document software.
    2. select file click on print.
    3. print box should open.
    4. check to see if your printer is in dialog box if not select your printer.
    5. then select printer options.
    6. set paper size click ok.
    7. click print.
    8. lst me know if that works.
    What document software are you using?
    Word is write do you have Microsoft office?
Canon pixma ip1000 black ink stop printing suddenly
Based on your explanation I will try to help.
Your ink tank had run out. You can refill it through the bottom of the tank or just simply replace your ink tank.
Aug 11, 2017 | Canon PIXMA iP1000
How can i print both sides of paper on my magiccolor5550
IF you have the optional duplex unit installed on your printer then when you go to print something, your printer setup screen should have a duplex/2 sided printing box you can check. This will be under printing preferences or properties. If you do NOT have the optional duplex option then you have to manually duplex. That means on say a 2 page document that you want 10 copies of you have to print 10 copies of page 1. Then take those 10 copies and place them back into the paper tray and print 10 copies of page 2 onto the backs of page 1.
Those are you 2 choices for duplex printing.
Good Luck and Thank You for using Fixya.
Nov 17, 2010 | Konica Minolta Magicolor 5450 Printer
Hi my omni 3200 printer is not printing. The page
You either have the wrong paper in the machine or it is in backwards. It takes thermal paper. Run your fingernail across the paper and if it makes a mark, that is the side which must be facing up when it goes trough the printer.
Jun 19, 2010 | VeriFone OMNI 3200 (P092-101-10) Printer
I select 10 page to print in laser printer hp1007 , but i need only 4 page , then i remove paper from trey after printing four page, then i want to delete printer job to print new page, but unable to...
No problem, it's with almost all printers in this "low" class.Always need to reboot the PC to delete documents in queue.The other way is waiting, but in some cases you will wait more than 10 mins.
Oct 26, 2009 | HP LaserJet 1020 Printer
Too much ink to few padges printed
The 1000-1500 mark is usually just a guess - it usually assumes no more than 15% coverage of the page.  If you are printing out very large pictures (full page images) or are printing lots of a single color (green landscape images), then the ink will run out a LOT sooner.
May 27, 2009 | Office Equipment & Supplies
How can I set up the paper size from letter to legal when i print? I am using the canon image class d340.
1. Access Page Setup in your application and set the paper size.
2. Do File -> Print and click the Printer Properties button to set the paper size before printing.
Nov 24, 2008 | Office Equipment & Supplies
Canon Image CLASS MF6550 not printing
hi kim
you have a stuck shutter in front of laser unit very common problem
charlie
Aug 19, 2008 | Office Equipment & Supplies
Black ink not printing
Same problem. Will print web pages in color, diagnostics work, but will only print photos in black.
Jan 19, 2008 | Epson Stylus 880 InkJet Color Printer
Canon imageclass MF8170c print problem
i have Image class MF 8170 c Just printing blank pages.no erro code
apear on display.
Jan 11, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
Printer will not print in Black at all
Had a similar problem.
It turned out to be poor quality ink refills that I bought at the local mall. Found a good ink supplier who charges $4.00 per cartridge.
Try removing the ink cartridge and cleaning with warm water or a little alcohol and a clean soft cloth or swab in the area where the cartridge is seated
Nov 27, 2007 | Epson Stylus 880 InkJet Color Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
120 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
