Question about Samsung RS2534 Side by Side Refrigerator
No cold water
The cold water dispenser on the front of my side-by-side Samsung refrigeraor stopped flowing. This happened a couple months ago the first time. At the time, I first tried changing the filter, but that didn't fix it. I then got my compresser and blew air up through the dispensing hose. It worked! For about two months. Now it's stopped again, and I tried the same thing, but no go. I unhooked the water line in the back and blasted air into it, but still no cold water. It's not the end of the world, but you do get used to cold filtered water and miss it when it dissappears. Any help would be appreciated.
  • 124 Answers
  1. Make sure filter is installed right.
  2. Disconnect water line see if water is flowing from line. May have a water valve in line not working.
  3. reconnect line but leave lose open inline valve just a little see if water flows out. No water PSI may be to low to reach up to fridge or valve stuck closed.
  4. Got water to connection tighten check dispenser for water.
  5. No Water If your system has a reservoir to store & chill water Your float may be stuck locate & check unstick if needed.
  6. Still no water May have faulty dispense value. Check value replace if needed.
Please rate hope this helped. If I can help further I'll standby.
Posted on Mar 09, 2009
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The cold water dispenser in my whirlpool refrigerator stopped dispensing water about 2 years ago. Recently it just started dispensing water and does not shut of. I had to close the valve to the water and...
Hi copy;
You may like to try the Water Valve (Solenoid) sounds like it may had stuck once now has become free and stayed open allowing too continually flow. It is behind fridge where the mains water is connected into fridge... Cheers
Mar 16, 2010 | Whirlpool GS5SHAXN Side by Side...
Water dispenser doesn't work
Replace the water valve on the refrigerator. The valve solenoid is stuck open causing water to flow freely. This should fix both issues with icemaker fill tube freezing and water dispensing.
May 05, 2017 | Whirlpool ED5SHAXM Side by Side...
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Watner dispenser gradually stopped working (slow flow to begin with)
you need to change the water filter, usually around $35.00.
May 23, 2009 | Maytag MSD2758GEW
Samsung fridge freezer fridge is registering 13 and not cold
Feb 23, 2009 | Samsung RS2534 Side by Side Refrigerator
Water dispenser not working. Model 54616.
ok i owuld look at the resevour tank and take a hair drier aand heat up the oiutlet till the water flows again.
Jan 02, 2009 | Kenmore 54613 / 54616 Side by Side...
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Samsung RS2534 Side by Side Refrigerator Logo
976 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
