Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water leaking from inside freeze.....
Appears there is a defrost heater around the coils at the bottom. Every couple of days I have a puddle of water on the floor that has come through the inside of the freezer. Where should this water be going??
  • syolanda Mar 10, 2009
    When the ice maker is full the water starts dripping from inside the freezer. I can't seems to find where the water is going but once I empty the ice bucket from the door, clear the stuck ice cubes and pit it back it seems to work just fine. Or the ice cubes get stuck in the ice tray as they're being pushed into the bucket in the door. The water seems to be more than just a trickle this time but I still can find where the water is going. I;ll check in a few minutes to see if the ice maker has started working again.
  • KitchenAid Master
  • 2,651 Answers
Common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Mar 09, 2009
Why do I have a puddle under my fridge every couple days but no sign of a drip or leak?
If it is an automatic defrost fridge the it will have a hose draining down into a container under the fridge, make sure it is draining where it should and has,not become dislodged. Some have a small tray with either pipes inside it or an electric heater. Some have a container sitting on top of the compressor, both of these are used to evaporate the water.
check to make sure there are no holes in the water catcher.
if you have an electric heater that is not functioning then the container will be already full of water and at each defrost cycle will overflow onto the floor.
Sep 08, 2014 | Refrigerators
There are several causis from water leaking from the back of the fridge did you check is not condensation? In case you will need to lower fridge temperature
Feb 24, 2008 | Whirlpool GS6NBEXR Side by Side...
Ge Monogram all in one refrigerator model zir36nmdlh is leaking and freezing food
There is a heater element that helps to defrost the coil, you may need to replace it.
May 04, 2014 | Home
Every couple of days there is a puddle of water coming from unit..shut off water source and still leaked water?! HELP!
Is the hose from the freeze compartment in the drain pan? Or is the drain pan leaking? The unit is going into a defrost and that is where the water is coming from. It drains into a drain pan where it evaporates over time......Check the drain line and the drain pan. Is there ice in the bottom on the freezer maybe the drain is pluged inside and the excess is seeping out the door during defrost. Hope this helps....
Mar 11, 2011 | Refrigerators
My frigidaire side by side freezer freezes up and the filter in the refrigerator leaks water. It makes ice fine but will not freeze ice cream. theres a big clump of ice in the back which is under a cover...
the leaking water is the problem. it needs to be fixed, but till then defrost again, use a fan it speeds the process, SHUT OF WTER to ice maker. restart fridge it will work normally. now find parts needed to fix the ice maker water feed.
the leaking water overwhelms the defroster. and causes a coil freeze up, this impedes cooling and air circulation over the evaporator coils
Jun 15, 2017 | Frigidaire FRS23KF7AB Side by Side...
I get a puddle of water inside of the the refrig every a couple days, I have turn off the refrig, and blow with the fan for over 5 hours, hoping that will solve the issue, however that didn't work.
check the seals for leaks. condensation from warm air leaking into the fridge through bad seals collects on the inside. also, if condensation collects on the evaporator coils, it'll freeze. then when it goes into defrost mode, all of the frost and ice melts into a condensate pan under the fridge. if the tube to the pan is blocked, the condensate stays in the fridge. so, check the seals and check the condensate tube.
Nov 09, 2009 | Samsung RS2630SH Side by Side Refrigerator
Model # TBX18TRBR large puddling leak on floor, think has to do with defroster messing up?? A GE refrigator serial # HG539639
I've got the same fridge with the same problem (believe it or not it was manufactured in 1992 so it's a wonder it's still working).
I also have been able to narrow the problem down to a defrost issue. It appears as the coils are defrosted, the leaking water drains down through the inside of the fridge, pools in the bottom of the fridge (under the bottom drawers), then when that area is full it runs out onto the floor.
I'm still troubleshooting and will post back here within a week with my results.
Aug 22, 2009 | GE Refrigerators
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Freezer leaking water
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 09, 2008 | Freezers
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
166 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
