Question about Roper RAS8445KQ Top Load Washer
My roper wont do anything
I did 2 loads of laundry and was on my third. everything was fine until the spin/rinse cycel. now it seems that my roper washer is dead. it has water and laundry in it.
  • gregger76 Apr 06, 2009
    Same problem, these washers are garbage. I hope my warranty will cover this problem..
  • 686 Answers
Is you washer sitting on a carpeted floor? If so ther is not enough air flow under it for the motor to not overheat. Maybe by now 4-3-09 it's functioning if not post me your model number. If it's on carpet raise it up with 3/4 inch boards under the feet.
Posted on Apr 03, 2009
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
Mar 30, 2009 | Kenmore Washing Machines
Washing machine wont go from wash to the spin etc automatically
Do not fool with this you will void the warranty, you have a defective machine, contact the manufacturer.
Apr 17, 2017 | Whirlpool GHW9400 Front Load Washer
Rinse water will not come through on spin
this unit might have a triple valve water soliniod, one for hot, one for cold, and one for rinse cycle. you can check by taking the top off and looking in the back were the hoses attach. the top comes off by 3 or 2 screws on the back of the machine near the top. now run a load of laundry and listen at this water valve when the time is right, be careful not to touch anything, if you don't feel good about doing this then don't. kelly
Dec 22, 2008 | Frigidaire Washing Machines
When I try to use my cold cycle on the washer it wont work.
Dear Customer
Please perform the following checks
check the lid switch if the switch is broken the washer will agitate but wont drain or spin
Plaese rate this,Thank u
Dec 17, 2008 | Roper RAS8445KQ Top Load Washer
I have a roper washe rmachine it wont spin
washing machine wont wash nor spin when time to rinse
Nov 22, 2008 | Roper RAS8445KQ Top Load Washer
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
205 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
